Old 03-27-2020, 04:47 PM   #1
fdbdw
fdbdw's Avatar
New motor whining noise
New 454, whining noise that increases with RPMs when cold then goes away after warm up. Hard to pin point with naked ear, threw on a stethoscope and my best guess is that it’s coming from the distributor ( but not positive). Anyone have any thoughts or experiences with this?
fdbdw is offline   Reply With Quote
Old 03-27-2020, 05:14 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: New motor whining noise
Can you make a recording and play it back for us?
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 03-27-2020, 05:19 PM   #3
fdbdw
fdbdw's Avatar
I can, I’ll have to let it sit overnight and get cold. Definitely a a whine and not a vacuum whistle. Best way I can describe it is, sounds like a blower whine.
Old 03-27-2020, 06:42 PM   #4
mikeshome
mikeshome's Avatar
Maybe try removing belts and start,eliminate everything at the front first,
mikeshome is offline   Reply With Quote
Old 03-27-2020, 07:54 PM   #5
fdbdw
fdbdw's Avatar
Stethoscope points me to the rear of the motor. Pulled distributor, gears look fine. I would be more worried about the gears not aligned but it goes away once warm. Working 24 hour shift tomorrow, be back at it Sunday.
Old 03-27-2020, 08:24 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
Are you using a solid steel cam gear?
~Steven
Simi Valley, CA
Old 04-01-2020, 08:34 AM   #7
fdbdw
fdbdw's Avatar
Yes, melonized steel gear
Old 04-01-2020, 08:38 AM   #8
fdbdw
fdbdw's Avatar
Update, gears on the dizzy don’t show any wear or markings. Got to thinking about it last night. Wonder if it’s the torque converter leading me to the back of the motor , freshly rebuilt th400. Another long shift today, gonna investigate that tomorrow
Old 04-01-2020, 09:41 AM   #9
jbarron
I had a motor doing this. Micro imperfections in the cam finish. Go search youtube for cam whine.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors
'72 3/4 Cheyenne Super 350/200R4
'50 1/2 Chevy 3 Window
jbarron is offline   Reply With Quote
Old 04-01-2020, 10:02 AM   #10
JMac11
JMac11's Avatar
Have seen BBC with High Volume Pumps pull the cam back towards the distributor causing wear between timing gear and block. Rare but drastic, check oil for metal or with distributor out check back and forth travel on cam.
JMac11 is offline   Reply With Quote
Old 04-01-2020, 10:04 AM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Starter bendix not retracting fully and starter gear teeth barely touching flexplate?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-01-2020, 11:32 AM   #12
Steeveedee
Who Changed This?
Steeveedee's Avatar
This can sometimes cause a whine. Though you have found it louder in the back.
~Steven
Simi Valley, CA
Old 04-01-2020, 11:47 AM   #13
garyd1961
Power steering pump?
garyd1961 is offline   Reply With Quote
Old 04-01-2020, 02:58 PM   #14
my67c20
Back of the engine, like near the passenger seat? If so experience tells me that is not going to go away for a loooooooong time.
my67c20 is offline   Reply With Quote
Old 04-01-2020, 03:29 PM   #15
weq92f
weq92f's Avatar
LOL.
I'm thinking dizzy related. Use some marking compound on the gear, assemble and rotate then check it.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 04-01-2020, 03:35 PM   #16
fdbdw
fdbdw's Avatar
Nailed it, sometimes I overlook the obvious
Old 04-01-2020, 08:13 PM   #17
JMD
JMD's Avatar
Newly rebuild TH400? Any performance upgrades in the tranny? I'd bet your transmission is starving for fluid, change the filter to a high flow/performance. I had the same issue with my newly rebuilt 454 TH400 combo. Changed the filter and it was good as new.
Edit* My issue sounded exactly like blower whine, changed with RPM as well as gear shifts, and went away as soon as the transmission warmed up.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline   Reply With Quote
Old 04-02-2020, 09:53 AM   #18
clay68c10
clay68c10's Avatar
I've had the same noise as well. Use the bronze mesh style filter, it will take care of it if that is the source.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 04-27-2020, 05:14 PM   #19
fdbdw
fdbdw's Avatar
Just wanted to update.
Turns out it was the torque converter from my TH350 I re-used in the TH400.
Had some fine flakes in the fluid . Replaced converter, fluid & filter , tranny all cleaned up
All good now, I appreciate all the input.
Old 04-27-2020, 05:53 PM   #20
Steeveedee
Who Changed This?
Steeveedee's Avatar
Good to see that it's fixed, and thanks for letting us know!
~Steven
Simi Valley, CA
