Old 03-28-2020, 09:39 AM   #1
maverickmk
maverickmk's Avatar
Is There an Easy Way to Know Which Size Clutch I Have?
I have now come to the part where I can actually drive my truck and on it's maiden voyage I realized why it most likely was parked. The clutch is gone. So, with that said, is there a way to tell if it's an 11" or 10" before I pull the trans? All the places I search have both listed and I would like to have all the parts on hand when I start so I can finish it in one effort. Does it even matter which one I get? It's a '69 250 cid 3 on the tree. Those are the specs I search under and get both clutch sizes.
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 03-28-2020, 10:04 AM   #2
bubbasimms
Re: Is There an Easy Way to Know Which Size Clutch I Have?
FWIW......I've got a 69 250 3 on the tree and it has an 11 inch. I just happen to have it laying here.
bubbasimms is offline   Reply With Quote
Old 03-28-2020, 12:55 PM   #3
twoskies
twoskies's Avatar
got an 11 in my 72 with a 4 on the floor, granny gear, i would make sure you buy a good flexplate, i went cheap and it flexes, ill probably end up having to drop the transmission at some point, not something you want to do twice
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
Old 03-28-2020, 01:07 PM   #4
maverickmk
maverickmk's Avatar
Flex plate? Those are for automatic trannys. There are 3 parts to a clutch setup: flywheel that is attached to the crankshaft, the actual clutch plate that has splines and is attached to the trans input shaft (slides over it) and then the pressure plate which is what the clutch pedal is attached to. What do you mean by "flexes?" Could it be a stiff pressure plate and you're getting some deflection in the clutch pedal mechanism/arm? There shouldn't be any flex in a clutch setup, unless you maybe need a different descriptor for your issue - ?
Old 03-28-2020, 06:46 PM   #5
Abomb
Do you have your SPID? If it says HD clutch, it will be 11 inch...if not, it will be 10....UNLESS, a previous owner has changed it...so, there’s really no way to tell until you have it apart...sorry...
Abomb is offline   Reply With Quote
Old 03-28-2020, 07:25 PM   #6
maverickmk
maverickmk's Avatar
My SPID has "Nothing here to see" printed on it
Nope, no HD on it at all. Thanks for the info, I appreciate it.
Old 03-28-2020, 07:52 PM   #7
rsavage
rsavage's Avatar
That looks like a 10 1/2" to me (often listed as a 10 3/8")
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 03-28-2020, 07:58 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
If you can get at the pressure plate, you can measure the distance between the bolts. Different diameter parts would have different separation distances. The bigger clutch would, of course, have the bolts farther apart. Then you can go to the parts store and have them pull both pressure plates to compare. It's been a dog's age (or two) since I've put in a clutch, but if there is just a thin sheet metal cover on the front of the flywheel, I think the bolt holes are tapped through. You could still measure it that way. HTH
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 03-28-2020, 07:58 PM   #9
twoskies
twoskies's Avatar
yes
Old 03-28-2020, 09:11 PM   #10
maverickmk
maverickmk's Avatar
I understand what you're saying, I'm just trying to cheat the system. I hate having to stop in the middle and run to the parts store. Not a huge deal, just one of my pet peeves. I'll just pull it and get the same. I was really hoping someone would say it makes no difference.
Old 03-29-2020, 02:41 PM   #11
maverickmk
maverickmk's Avatar
I got the clutch pulled out today and now I am stumped as to the size. Do I order an 11" or a 10"??? It measures almost exactly 10 1/2".
And isn't that clutch a beauty
Old 03-29-2020, 02:58 PM   #12
Steeveedee
Who Changed This?
Steeveedee's Avatar
Missing pieces usually means someone was side-stepping the clutch.
~Steven
Simi Valley, CA
Old 03-29-2020, 03:31 PM   #13
RustyPile
RustyPile's Avatar
I got the clutch pulled out today and now I am stumped as to the size. Do I order an 11" or a 10"??? It measures almost exactly 10 1/2"........................….And isn't that clutch a beauty
It's exactly what the tape measure says --- 10 1/2 inches.. Don't "order" anything.. In these hard times, support your local economy.. Take your wore out pressure plate, clutch disk, and throw out bearing to the local auto parts store and tell them you want a 10 1/2 inch clutch kit.. They'll want the old stuff for a core.. If your flywheel looks anything like the pressure plate, it'll need refacing also...
RustyPile is online now   Reply With Quote
Old 03-29-2020, 10:48 PM   #14
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yup.
~Steven
Simi Valley, CA
Old 03-30-2020, 08:42 AM   #15
maverickmk
maverickmk's Avatar
So I need to get a 10 1/2" clutch? That's absurd, they are only available in 10" or 11". I'm not telling anyone I need a 10 1/2" clutch Have you ever replaced a clutch? It always helps to do a little research.
Old 03-30-2020, 09:04 AM   #16
Grumpy old man
Grumpy old man's Avatar
Summit about $200.00 with free shipping
Zoom MU Series Clutches MU5473-1B
Pioneer Flywheels FW-100
double check part #s and buy new ARP flywheel and pressure plate bolts and you'll only have to do it once . don't resurface heat checked flywheels .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 03-30-2020, 09:27 AM   #17
maverickmk
maverickmk's Avatar
Rock Auto has clutches for $75.00 with $10.00 shipping. I have a 5% coupon code which just about covers shipping. Locally, the cheapest I can find is a 10" for $120.00.
Old 03-30-2020, 03:20 PM   #18
RustyPile
RustyPile's Avatar
They ARE available in 10 1/2, you just have to know where to go shopping.. Obviously, you don't know who you're talking to.. I'm a retired automobile mechanic.. Started my first job when I got out of the military in 1966.. I worked the field for over 35 years.. The last 10 years I worked as a drivability technician. Along with my wife, we owned a shop for 12 years. Among other areas, I'm certified in electrical, ignition systems, power trains, brakes, and cooling systems..
Son, I've had wrenches in my hands for over 60 years.. How many clutches have I replaced?? Counting front wheel drive and foreign built, oh, probably somewhere in the thousands..
So can the smart ass attitude in my presence..
Old 03-30-2020, 03:47 PM   #19
maverickmk
maverickmk's Avatar
So, you are stating, unequivocally, that GM put a 10 1/2" clutch in and all of the auto parts stores & online parts sites are wrong. I challenge you to find a 10 1/2" clutch for a 1969 GMC 250 3 speed. Not one that is listed as a 10" or 11" and actually measures 10 1/2". I'll wait.
Old 03-30-2020, 06:24 PM   #20
RustyPile
RustyPile's Avatar
You "challenge" me??? What a joke. I have nothing to prove.. I'm not the one looking for a clutch.. They're out there, go find it yourself.. You've pissed me off so I'm done with helping you...
Old 03-30-2020, 06:25 PM   #21
AussieinNC
Moderator
AussieinNC's Avatar
Gentlemen please....some manners please...
10 1/2" clutches were common on a variety of Chevrolet products...
see
https://www.partsgeek.com/gbproducts...AaAst3EALw_wcB
A simple google search using Chevrolet 10 1'2 clutch kit will return many results....
Have fun everyone and stay safe
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 04-03-2020, 10:44 AM   #22
maverickmk
maverickmk's Avatar
If anyone cares, if you pull out a clutch from a 250 cid I6 and it physically measures 10.5" you need to order a 10" clutch, not an 11".
Old 04-03-2020, 12:44 PM   #23
geezer#99
geezer#99's Avatar
Interesting!
If the disc measures 10.5 then what does the pressure plate measure?
Old 04-03-2020, 01:02 PM   #24
maverickmk
maverickmk's Avatar
Originally Posted by geezer#99 View Post
Interesting!
If you look at the picture I posted it measures 10.5" as well.
