Old 03-28-2020, 12:15 PM   #1
prairieschooner
prairieschooner's Avatar
Finicky Fuel Fill
Mine is a 1975 C10.
It has been a pain in the butt to fill the tank since I bought it. At least here in California with the Fuel Pumps (SMOG Crap) with the recovery hose. We were in Arizona for a while and no problem with filling.
Any of you guys have a repair or solution? I would rather not relocate the Filler Tube but if needed that may be an option.
Thanks in advance
Steve
Steve 1975 Chevy C10 Short Bed Fleetside
prairieschooner is offline   Reply With Quote
Old 03-29-2020, 08:54 AM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Finicky Fuel Fill
I always just had to hold the nozzle sideways when filling my '78. That helped keep it from kicking off.
Old 03-29-2020, 10:03 AM   #3
Getter-Done
Getter-Done's Avatar
There are several different filler necks.
I found a 86 Chevy with a 6.2 diesel.
The filler neck was opened (with no emission crap)
also the hose was bigger.
I used the tank and filler neck on that truck.
It made the fill-up easy.
You may want to look for this set-up if your emission will allow it.
Here is a link below , I found for the filler neck.
I don't know if you could adapt this to your current tank ,
Because the inlet tube on the tank is probably smaller. Hope this helps.
Link:https://www.ecklers.com/1984-1987-ch...All%20Products
The early bird gets the worm,
85 Chevy K-20
Old 03-29-2020, 10:38 AM   #4
prairieschooner
Thanks guys! I have been trying to keep the Pump Nozzle slanted and that helps a little. Still doesn't fill like the earlier type, I could actually set it on full and walk away when in Arizona.
I'll have to contact Eckler's and find out about that Filler Neck. Bummer is that I ordered 2 new tanks before we started our winter travels to get out of the snow and surely can't return them now.
.[/QUOTE]
