Old 03-29-2020, 09:12 PM   #1
SactoJim
SactoJim's Avatar
RideTech Shocks Question
Finally bit the bullet and bought some single adjustable RideTechs (Fox) shocks. So I've installed some new lower control arms and spindles. So with the truck on the lift and front suspension at full droop, the shocks won't fit (not long enough). These are the correct size shocks for my ride height for sure and I can compress the suspension till they line up (fully extended)......BUT i don't think I want the shock to act as the stop for the suspension to fully droop......I imagine it's not built for that and will f up my shock.......any insight and solutions. I'm figuring I will need to find a bump stop to install on underside of the upper control arm?
Thanks.....Jim
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 03-29-2020, 10:35 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: RideTech Shocks Question
Shock are suppose to not let the suspension fully droop. You are suppose to support them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-30-2020, 10:38 AM   #3
SactoJim
SactoJim's Avatar
I figured but had to ask anyway!......thank you sir.
- supercharged 383
- 4 wheel discs
My Build Thread
Old 03-30-2020, 05:28 PM   #4
68is4me
68is4me's Avatar
I went through the same thing a couple of years ago. You don't want the shocks to be bottomed out. At least ride tech is really easy to work with, I went through 3 sets before I got the correct ones.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 03-30-2020, 06:54 PM   #5
HO455
Post Whore
HO455's Avatar
As previously stated the shocks will limit the suspension droop. The important part is that they do not bottom out before you hit the bump stops or they will fail. (Been there, done that.) That's why it is so important to get the correct compressed measurement when ordering shocks for a lowered vehicle.
RIP Bob Parks.
Old 03-30-2020, 07:38 PM   #6
KMC3420
KMC3420's Avatar
I am going through this exact scenario right now with my HQ’s and they would be protected when your upper bump stop is installed. Just depends on the length of your bump stop though, if it makes contact before your shock is fully extended. I have these ordered. Bumstops
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 03-30-2020, 07:52 PM   #7
3767
My control arms came with the bump stops. Reading your first post, the shocks are at the very least not to far off what u need. My question 2 u is this....does your lower arm have a set up for different settings for the shock/spring. Mine has 3 different settings I can use. I use the outer most 1. This puts more of an angle but it also gives it a little better handling n return. If yours is that way(most I have seen are) then yes u may need longer shocks. While u have them, measure the difference n length from what u have and what u need. May i ask who u bought them from? Most vendors are willing 2 help get it fixed. Also keep n mind that by turning the bottom nut up u are changing the ride height. So if u are sitting a little low by what u want on the ground then turn that nut up to "dial n" what u want it 2 b. Is it possible to post a pic of what u have? This may help things out.
3767 is offline   Reply With Quote
Old 03-30-2020, 09:41 PM   #8
SactoJim
SactoJim's Avatar
I do have the correct shock for my ride height and measurement of the shock mounts at ride height. Got the shocks from Matt at MCB. I have tubular upper and lower controls arms.....LCA by CPP and uppers from Brothers......I don't have options for shock mounting location. I was just confirming not letting the shock support suspension droop. I will just need to figure bump stop to keep that from happening. Won't be a problem wiht driving around and will only be a concern when the truck is jacked up from the frame and suspension is unloaded. Thanks for the help as always guys.
- supercharged 383
- 4 wheel discs
My Build Thread
