Old 03-30-2020, 01:23 AM   #1
chev-obsession
chev-obsession's Avatar
Ac swap question
Hey guys,
I’m in the middle of my ls swap, and looking forward at what I have ahead of me. I need to find a way to make the factory AC controls turn on the ls A/C compressor. I was looking at my factory AC wiring harness and it looks like when the diverter flap opens, it pushes on a switch that has 2 wires (yellow and green) looks like the green would go to the SBC AC compressor. The company that I had tune and rework the LS harness and pcm gave me an “AC request” wire going into the pcm.
Can I run the green wire that originally turned on the SBC ac compressor to the “ac request” wire going into the pcm to tell the pcm to turn on the ac compressor? Hope that makes sense! Any help is appreciated.
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 03-30-2020, 05:50 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Ac swap question
Yes, that would be how its wired. However, it will need a relay, does your harness have that? Also, it generally only works on older engines. What year engine/PCM are you working with?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-30-2020, 12:44 PM   #3
chev-obsession
Yes, the harness has a relay for the AC system. As far as the year... It's an '05 from a tahoe, its the blue/green PCM. The company who did the work said they made the PCM think it is an express van since they are behind the times from the trucks/suv's and that it should work the ac system through the PCM.
1965 c/10 swb
1969 c/10 lwb
