03-30-2020, 09:51 PM | #1 |
Old member
Wasted a whole day
Well seeing how most everyone is lock up on their home steads I wasted a whole day today on the speed warning speedometer that was give to me. I had taken it out of the 3 hole cluster and installed it in my 7 hole once I got the new tach.
Well I started installing it this morning at 9:30, I just finished and it's back on the work bench in the garage. When I went to install it I stopped once I had the oil line hooked up and tach and the electrical stuff done to check it all before finishing. Glad I did I had no water temp reading... what the heck I didn't touch it. So I pulled it back out and looked it all over thinking I missed something. Spent 2 hrs and 2 gauges later and nothing. So I went a head and installed it all to go for a drive and check the speedometer. Guess what...it didn't work either it bounces all over the place, I guess the spring is gone I'm not sure. So I drove it back home took it out again and put the old speedometer back in it. I just have come inside form putting it back together. I decided to go a head and do a thermostat swap also. The water temperature gauge is working again. It's been a long day! https://www.youtube.com/watch?v=Nhfn4b0rWs0
03-31-2020, 12:10 AM | #2 |
The Older Generation
Re: Wasted a whole day
If you didn't have bad luck you wouldn't have any luck at all.... LockDoc
03-31-2020, 12:13 AM | #3 |
This makes you appreciate your good days
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
03-31-2020, 09:10 AM | #4 |
Old member
Yea sometimes it just don't pay to try and make your truck better. It fault me the whole time. On top of all that the speed waring speedometer broke some how. When I took it out the adjuster that turns the needle fail out of it. The plastic had snapped into!
Life goes on.
03-31-2020, 11:46 AM | #5 |
I am glad to see that my truck isn't alone in fighting change. Seems like when i try to fix one thing, something else jumps in wanting attention.
Brian |
03-31-2020, 07:42 PM | #6 |
Old member
I boxed up all the speed warning parts I had and shipped them to Tom in Junction City, OR this afternoon to fix the newer speed warning one and to give him the other parts.
