03-31-2020, 06:10 AM | #1 |
Location: Herculaneum MO (20 minutes south of St. Louis
Correct brake line connections?
I have a 67 C10 that has been converted to front disc using 71-72 parts. I'm almost certain whoever did the conversion plumbed it wrong. It has the front of the master cylinder plumbed to the front of the proportioning valve but then the front of the proportioning valve plumbed to the rear brakes. Shouldn't the front of the proportioning valve go to the front brakes?(this is how my wife's 72 is plumbed & I don't see why someone would have changed it.)
Can someone please confirm for me which way is correct?
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
03-31-2020, 07:23 AM | #2 |
Re: Correct brake line connections?
This should be how the 72 prop valve is set up.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
03-31-2020, 09:18 AM | #3 |
Using rpmerf's diagram your larger master cylinder reservoir will go to the front brake inlet and the smaller reservoir will go to the rear brake inlet.
03-31-2020, 10:04 AM | #4 | ||
"I ain't nobody, dork."
Thanks for that diagram rpmerf!
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
04-01-2020, 06:13 AM | #5 |
That might be in theory. However in reality I have three 71-72 proportioning valves. None have a fitting on the top where your illustration says front brake outlet. They all have an outlet on the bottom where the illustration says can be used or plugged
04-01-2020, 06:15 AM | #6 |
Either way this truck is plumbed backwards. Thanks for the help
04-01-2020, 07:36 AM | #7 | |
There are multiple "tunings" and configurations released based on GVW, brake system, wheelbase, etc. You really can't just grab one randomly and throw it on without knowing what it came from, or ideally the meter/split/slope characteristics of that specific valve. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
