03-31-2020, 09:50 AM | #1 |
H072 DRW 4.56 Differential
Have a 1970 Eaton DRW 4.56 rear end complete w/new brakes 3000 mi. ago pinion seal leaks. Cab and Chassis 40" spring perch centers $100 local pickup. 95386
11-09-2020, 10:47 PM | #2 |
Re: H072 DRW 4.56 Differential
Anybody with a cab n chassis need this? Located in the central valley near Modesto
11-10-2020, 08:22 PM | #3 |
Being it’s pre 71 and 4.56. I’d say pull the center section and drums, trash the rest. That is if you need the room.
You really need taller tires to make this gear work for today’s speeds
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
11-11-2020, 01:00 PM | #4 |
DND Trucks
Imo,
This Eaton rear is a steal at 100.00. Try walking into any salvage yard looking for one then buy it for 100.00, a bit unlikely. The 3rd member 4.57 gears are low even with OD but mud truck, rock crawlers or any off road folks can't find enough of them. Fwiw, 4.10 3rds are out there and can be swapped easily, if you still wanted use the DRW HO72 set up. You can get new drums for the DRW but are made by 1 manufacturer priced at a little over 100.00 each. Last edited by Dave; 11-11-2020 at 01:15 PM. |
11-11-2020, 04:40 PM | #5 | |
10-01-2021, 08:55 PM | #6 |
Bump......still have it
