03-31-2020, 04:01 PM | #1 |
B-Pillar
Fixing to attack my drivers side B-Pillar, can you guys post some pictures of your dealings with this area just so I have a better idea.
I ordered the rocker box reinforcement piece, both B-Pillar patches since it's all rusted. Any pictures would be helpful! Thanks. |
03-31-2020, 04:58 PM | #2 |
Re: B-Pillar
Start at post 78 and read forward.
http://67-72chevytrucks.com/vboard/s...=341224&page=4 Another thread with good pics http://67-72chevytrucks.com/vboard/s...light=b-pillar More good pics http://67-72chevytrucks.com/vboard/s...light=b-pillar Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
03-31-2020, 10:08 PM | #3 |
Re: B-Pillar
get some pix of what you are starting with - many of us can tell you what you are in for by just seeing a few pix of you truck at the b-pillar.
Welcome to the forum! |
04-01-2020, 11:38 AM | #4 |
Re: B-Pillar
04-01-2020, 12:51 PM | #5 |
Re: B-Pillar
Take a look at this thread for another blazer -
This post has links to most of the aftermarket parts to rebuild these trucks now. Over the past 3-5 years - the ability to build one from the ground up is WAY easier. |
04-01-2020, 01:46 PM | #6 | |
Re: B-Pillar
04-01-2020, 02:44 PM | #7 |
Re: B-Pillar
Jump on in, misery loves company!
Good luck, Rg
04-01-2020, 04:57 PM | #8 |
Re: B-Pillar
looks like quite a few panels are in rough shape. you are at a cross roads - buy patches to weld in or replace the metal completely. I have now done it both ways.
Before you cut anything - - bolt on the factory hard top - check the body mounts/bolts - if they are rusted/gone - replace keeping track of shim count and locatin - check how the doors open/close - shim until they open and close normally If you don't do these steps first - you are rolling the dice on the fixes you make (time and money spent) - not being done on a solid platform to start. On one of my projects - (after doing all the items above first) I replaced the entire back half of the truck to new sheet metal. I measured the door opening at each step and confirmed I was still within spec. It was pricey, but the parts are all clean and bolted together w/o issue. It took me 3 weeks over last summer to get it all buttoned up. I have since put the top back on and drive it a few times a week when weather permits. It won't see salt/rain while I own it. Last edited by lks dcvn; 04-01-2020 at 05:05 PM. |
04-01-2020, 04:58 PM | #9 |
Re: B-Pillar
Hard top has been on, body mounts are good, doors open and closed fine before I took the drivers door off.
04-01-2020, 05:05 PM | #10 | |
Re: B-Pillar
I already have all of the patches, minus the BPillar patch (the expensive one) lol.. going to try to make that one. |
