Old 03-31-2020, 05:19 PM   #1
mike in mo
c30 factory rear sway bar end links
anyone got a good part number for 1979 c 30 dually camper special 4 door sway bar end links or a number for a kits that will work?
mike in mo is offline   Reply With Quote
Old 04-01-2020, 09:31 AM   #2
SCOTI
SCOTI's Avatar
Re: c30 factory rear sway bar end links
I don't recall anything special about the end links that came off my CC 2wd dually. If you have the pieces required for the assembly, standard aftermarket bushings would work as replacements.
Are you missing something?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 04-01-2020, 10:45 AM   #3
mike in mo
this truck was a basket case when i got it and the guy that took it apart didn't keep any of the old parts so i have the spring plate bar mounts the bushing brackets and the bar it self. i cant find a end link kit to order and have no old parts to go by to know how long the spacers and bolts in the end link need to be.
Old 04-01-2020, 01:18 PM   #4
SCOTI
SCOTI's Avatar
I'll look through my dually parts. I should have the end links & can get you a length.
Beyond that, it's just the bolt that goes through the sleeve & the bushings/washers @ each end. I always upgrade to Energy Suspension pieces there as well as up-size the bolt (they're usually 5/16 so I step up to 3/8). Worst case, you can always go shorter or longer on the sleeve. I usually trim them shorter to allow the bar to do it's job sooner but my stuff is always getting lowered.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-01-2020, 08:26 PM   #5
my86lb
Here you go
my86lb is offline   Reply With Quote
Old 04-01-2020, 08:51 PM   #6
my86lb
Energy Suspension Sway Bar End Link Sets 9.8149R is universal
Old 04-02-2020, 09:00 AM   #7
mike in mo
Thanks alot I think I can get it now.
