Old 12-09-2003, 05:36 PM   #1
als70chevy4x4
als70chevy4x4's Avatar
stock vaccuum guage hook up
recently bought a dash bezel with the stock tach in it.it was in a 72 chev1/2 ton 2wd.i didnt notice at 1st but in the hole next to the oil pressure thats usually empty on most other trucks ive seen was what im told is the vaccuum gauge.it kind of threw me off because theres no wording on the plastic lens cover,its been scrapped off im assuming.Im wondering how to hook this up properly and just how rare an option is this or if it even came in the 70-72 1/2 ton models?
als70chevy4x4 is offline   Reply With Quote
Old 12-09-2003, 07:09 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Not an option in the 10-30 pick ups. In the bigger trucks it was avaliable though...possably on 30's...not sure on that though.
Just run a vacume line to manifold vacume...any port on the intake, or on the lower 1/2 of the carb. If it only reads once you tap the throttle, then you need to look for another vac port that is lower.
Old 12-09-2003, 10:14 PM   #3
1969 GMC
1969 GMC's Avatar
does the bezel have a piece of plastic blocking off the area where the steering column goes? if it does, it is from a C/40-60 series. even if it doesn't, I am about 99% sure that the vac or air pressure gauge were never available on the 10-30 series, and it just has a correct replacement bezel for a 10-30 series.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-10-2003, 12:53 AM   #4
Longhorn Man
This pic shows what he is talking about.
Also note the text for the guage. This one is an air pressure unit, but the vac set up is the same.
Old 12-10-2003, 01:19 AM   #5
dinnut
dinnut's Avatar
most vendors sell the tach/vacuum dashes new for 500 bucks. they go for more than that used because they are original
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-10-2003, 04:17 PM   #6
als70chevy4x4
Well I paid 120 Cnd so that makes me think I got an ok deal lol.
Old 12-11-2003, 12:22 AM   #7
dinnut
dinnut's Avatar
you stole that thing!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
70 longbed
496/th400/Ford 9"
Old 12-11-2003, 01:59 AM   #8
1969 GMC
1969 GMC's Avatar
i believe board member VTKidder bought a tach/vac dash from a junkyard for $20. talk about a steal.
1969 GMC K2500
1996 Honda Accord
