Old 04-01-2020, 11:21 PM   #1
whateverpratt
k10 cab mount brackets
Question: are the rear cab mount brackets the same for 2wd and 4wd trucks?
Background:
I've got a '62 k10 frame.
PO torched the rear cab mount brackets and welded them back on a few inches to the rear, and a few inches higher (maybe for the chewed up '65 cab that he put on there?)
I plan to cut them off, knock out the original rivets, and replace with a factory bracket.
Do I need a 4x4 specific rear cab mount bracket, or is a 2wd rear cab mount bracket the same as the 4x4?
Did the 4x4 rear cab mount bracket change in '63, or were they the same from '60-'66?
I'm putting a '63 cab on this frame, and I'm under the impression that the rear cab mounting position did not change from '60 to '66.
'66 c10 rust bucket, 350 (pulled and sold, now waiting on 4bt install) nv4500 stock bellhousing, '85 c30 front suspension and 3/4 rear coils with 4.10 H072 rear axle
NV4500 install http://67-72chevytrucks.com/vboard/s....php?p=6488778
Suspension update http://67-72chevytrucks.com/vboard/s....php?p=8236775
whateverpratt is offline   Reply With Quote
