Head lamp Issues
This has me baffled.
I installed a premade LMC head lamp harness with relays for my new h4 head lamps. The lights works fine before the install. on low beams , the low beam is bright as it should be but the high beam is on also but dim ? Then if I switch to HIGN beam , the hi beam is bright as is should be and the low beam lamp is dim and it shouldn't be ? In other words on low beams the high beam shouldn't be on at all but on H Beams both should be on bright but the low beam is dim. What the H*** is going on ? Cross wire ? Last edited by LockDoc; 04-03-2020 at 08:34 PM. |
![]() Join Date: Jan 2001
Re: Head lamo Issues
I would bet you're missing a ground wire.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
yup run another ground from the rad support to the frame
1967custom |
![]() Join Date: Nov 2018
Yep.... 90% of electrical problems are grounding issues.
Bad ground is the first thing I checked. I grounded right to the battery.
So then I thought maybe bleed over in dimmer switch , No not that either. So I tested both low and hi beam wires separately , No bleed over . On low beam no power bleed over at Hi beam and on Hi beam , no power bleed over at low beam wire. using a testor. It's got to be in the harness some where . Like I mentioned earlier , prior to the new H4 harness , everything worked fine grounding as should be. |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
I still think it's a ground problem. It sounds.like its trying to use the high beams for a ground.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#7 | |
I pulled the harness and hooked up my original harness with original grounding points and guess what they work as they should. I hate 12 volt systems. |
![]() Join Date: Apr 2016
I think you may have found your problem: "installed a premade LMC head lamp harness"
Sound like it may have a break within it's ground circuit. Test the continuity within the ground legs of the LMC harness.
1972 GMC K2500 Super Custom Matt |
Re: Head lamp Issues
Typical LMC crap parts. I wouldn’t buy a license plate frame from them.
Garbage parts
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com Last edited by rockyrivermark; 04-04-2020 at 09:23 AM. |
Old member
There are post about the LMC head light relay harness having problems in the past. Do a search on here to find the links about it.
Wires crossed up all kinds of stuff. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Thank you , what an eye opener. I should have guessed , not all my experience with LMC has been bad . But they haven’t a clue about anything except sales !
#13 |
I just installed one the other day with the same issue. I thought it was odd that the harness only tied into the factory low beam plug and nothing into the factory high beam plug which could have something to do with it.
I am very mechanically inclined but shy away from wiring but I guess I need to just install relays into the factory harness. |
#14 | |
#15 |
Old member
It's a pretty easy upgrade really.
Take a test light and pull the head light connector off the drivers side light. With the test light on one of the contacts figure which wires are which...High/low. The drivers side connector works both lights. Then cut them about 12" away form the light. Take the end from the harness and this will be your trigger wire for the relay # 86 in the picture to the H beam one you are doing. Then the end to the head light goes to #87. You can run a #10 are #8 wire from the battery for the hot wire to the relays # 30 on both with inline fuse. Then ground each relay #85 to a good ground close to the relay. Repeat this for both relays. There is no use in using 4 relays for the GMC truck's, 2 relays will handle both lights easy. ![]()
#16 |
Lmc kit on my 70 gmc.
#17 |
Well the problem is fixed, The solution came when I read an old post by
Irishbleueyes and others on this site. We have awesome people on this Forum ! He ran into the same problem and found the wiring to the low/high beam head lamp was back wards. I used my AAW wiring diagram to rewire the 3 prong plugs . Bingo everything works correctly. So if you have the LMC harness , more than likely , it's wired wrong. Lmc , sent me a brand new one because I *****ed. But of course it's also wired wrong Last edited by mygmctruck1; 04-05-2020 at 03:13 PM. |
#18 |
Good deal. Thanks for letting us know what the fix was.
#19 |
laying low
![]() Join Date: Mar 2001
This is good to know now. I bought one of their kits a while back but haven't yet installed it. I'll be looking for this issue. Thank you.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#20 |
Interesting. I need to check mine. I did run into an issue with the kit. After sitting over the winter, my brand new battery was drained (started only a few times over the cold spell), and the wiring on the LMC harness was split in places and had the electrical crud buildup (like you see on the battery terminal posts) coming out of the wiring.
I cleaned it up the best I could and haven't had an issue since. But, I'm thinking I need to take it off of the truck and try something else. I need to look at the lights when they are on and see if I'm having the same issue.
1971 C10 - Hugger Orange/White My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197 LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460 |
#21 | |
#22 |
Ok here what I did to the LMC wiring harness.
Looking at the back of the 3 prong plug , the left pic is the correct wiring and the diagram on the right is how the LMC harness is wired . The Bl or ( gr ) wire goes in the left slot The Tan / Brown low beam goes in the top center slot The Green Hi beam goes in the right slot . This applies to both plugs for the Low / Hi beam plug , The high beam only plug does not change. As you can see LMC’s harness is WRONG but being from China I am not surprised . Last edited by mygmctruck1; 04-06-2020 at 08:14 PM. |
#23 | |
Who Changed This?
![]() Join Date: Jan 2013
