04-02-2020, 03:52 PM | #1 |
Rear leaf spring hangers
I just picked up a 72 K5. Someone took off the rear leaf spring hangers and bolted on some leafs that are several inches longer than the stock leafs. I am going to take the whole mess off and return it to original. My question is, will the hangers from any 67-72 k10 be the same? And also, would a 2wd c10 that has rear leafs have the same hangers? Thanks in advance.
1970 SWB Build |
04-02-2020, 05:04 PM | #2 |
Re: Rear leaf spring hangers
You need 72 4wd hangars, they are much taller than 2wd and 72 only. Put up a want to buy on the parts forum, some will pop up.
04-02-2020, 07:45 PM | #3 |
OK thank you! So to be clear, the hangers for a blazer are the same as k10 as long as the k10 is a 72?
1970 SWB Build |
04-02-2020, 07:51 PM | #4 |
04-02-2020, 07:53 PM | #5 |
Check here with dwayne
http://67-72chevytrucks.com/vboard/s...d.php?t=784007 |
