Old 12-09-2003, 06:52 PM   #1
soulman67
Randy churchill
soulman67's Avatar
67 C10 forsale again
This time it has to go. I bought this truck 3 years ago and drove it everyday for 18 months. I put a built 454 in it and went threw 2 automatic trannys and let it sit for a year with out starting it. I just recently installed a 4 speed trans with a granny gear. After starting the truck and letting it run it started smoking and using oil. It is an unfinshed project that I would like to get $3500 dollars for as is with a few extra parts. All it needs is a driveshaft and exhaust to drive it on the street. It has some rust on the passenger side front fender behind the bumper, in both door coners, and passenger side cab coner. The tailgate is ruff but I have another on thats in disent shape.
1983 GMC K2500 6.2 diesel 4" lift on 35x12.50 tires
2008 GMC 2500HD 6.6 diesel 3" lift on 315 75 16X10
2003 Jeep Rubicon 4.5" short arm lift
1985 Jeep CJ7 30k in parts and still adding up
soulman67 is offline   Reply With Quote
Old 12-09-2003, 06:53 PM   #2
soulman67
Randy churchill
soulman67's Avatar
this what you get for $3500
Old 12-09-2003, 06:55 PM   #3
soulman67
Randy churchill
soulman67's Avatar
you can email me for more info at randallchurchill@yahoo.com
Old 12-09-2003, 09:21 PM   #4
smoky02
Location: Sunny, Florida, some might call it South Alabama
is it a short bed or long, I can't really tell
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 12-09-2003, 09:37 PM   #5
soulman67
Randy churchill
soulman67's Avatar
Its a long wheel base truck, I started gathering parts for a disc brake swap, I have the spindles calipers, which am throwing in with the truck all you need is the 6 lug rotor kit from Gmc pauls and a brake booster. I also have a 92 chevy truck tank with sending unit that I am alos including in the truck. I started installing fractory ac parts but I don't have everything. I put in a steering column from a 92 chevy and gas pedal from same vechial. The interrior door panles and seat where recovered 2 years ago. To the orginal pattern the bench seat was an orginal cloth and vinyl seat. The truck still has the orginal heavy duty coil springs and rear overloald springs with the factory swaybars. The truck has 74,000 orginal miles so the suspension is in great shape. It has a new rearend a used trany with 143,000 miles on it, and a rebuilt 454 with lots of goodies and surprizingly easy on gas.
Old 12-09-2003, 09:41 PM   #6
smoky02
Do you have anymore pics??
Old 12-09-2003, 09:45 PM   #7
soulman67
Randy churchill
soulman67's Avatar
The motor alone cost close to $5000 to rebuild. It still has the stock bore, It does however have a 396 crank and heads. So it really is a 427. It has the biggest pushrods you can buy for a big block. A wiend action plus intake, edelbrock 750 cfm carb, Chrome 6 in tall air cleaner, chrome tall valvecovers, dynomax headers, march pulleys and brakets just for alt. It has somewhere between 11:1 and 12:1 compression. But because it sat so long without running it will need valve seals and all the other gaskets that might have gone bad. It runs but it smokes.
Old 12-09-2003, 09:46 PM   #8
soulman67
Randy churchill
soulman67's Avatar
Here is the other pic I have of the interrior its an old on before I put in the trans and new column
Old 12-09-2003, 09:47 PM   #9
smoky02
you said it was pretty easy on gas to??
Old 12-09-2003, 09:50 PM   #10
soulman67
Randy churchill
soulman67's Avatar
I have a pic of the engine compartment while I was in the process of installing the big block. The pic doesn't show the new 4 core radiator and radiator hoses, are the ac housing that I installed.
Old 12-09-2003, 09:53 PM   #11
soulman67
Randy churchill
soulman67's Avatar
Yes it was in the truck I orginally built it for. I had first installed it in a 92 3/4 ton with a 5 speed and got 15 mpg out of it in that truck. I haven't got to drive it in the 67 maybe a couple of times cause it went through auto tranys fast about as fast as I could put them in. I would guess probably 10mpg with the overdrive.
Old 12-09-2003, 10:06 PM   #12
smoky02
I would love to have that motor, but I'm sure I can't afford it
Old 12-09-2003, 10:24 PM   #13
soulman67
Randy churchill
soulman67's Avatar
I will sell that motor and everything to install it for $1500. or best offer.
Old 12-09-2003, 10:27 PM   #14
smoky02
I don't have enough right now, especially not with Christmas so close...but if you don't mind me asking, what does it take to install a BB
Old 12-09-2003, 10:39 PM   #15
soulman67
Randy churchill
soulman67's Avatar
motor mounts towers, oil presure lines and gauge because it has a 80 psi oil pump. 4 core radiator and radiator pads and mounts.
Old 12-10-2003, 01:07 AM   #16
fatfords
fatfords's Avatar
Randy,
That looks like a great project! Too bad you have to unload it-and too bad I already have too many! Did you get my message on the column? If not, let me know and I will resend it.
Thanks,
Kent
'56 F-100 (w/all GM stuff)
Lookin' for another parts chaser!
'05 GMC crew cab
fatfords is offline   Reply With Quote
Old 12-10-2003, 03:07 PM   #17
soulman67
Randy churchill
soulman67's Avatar
ttt
Old 12-11-2003, 09:09 PM   #18
soulman67
Randy churchill
soulman67's Avatar
I will sell just the motor and trans for $1500.
Or just the truck with no drive train for $1500.
Will sell complete for $3000 obo.
I can deliver the truck for the gas money to get their and back.
Old 12-11-2003, 09:10 PM   #19
smoky02
that's actually a good deal, but I can't do it at this time...
Old 12-11-2003, 09:13 PM   #20
soulman67
Randy churchill
soulman67's Avatar
I will trade for a 92 or newer 3/4 ton chevy.
Old 12-11-2003, 09:17 PM   #21
soulman67
Randy churchill
soulman67's Avatar
Hey smoky02 how much are you looking to spend on a big block, I know of 2 other bigblocks in my area that are cheap but they will need to be rebuilt.
Old 12-11-2003, 10:20 PM   #22
smoky02
how much are they??
Old 12-12-2003, 01:08 AM   #23
soulman67
Randy churchill
soulman67's Avatar
I am not sure they are at a junkyard, the owner told that he had two I can go ask.
Old 12-12-2003, 01:16 AM   #24
smoky02
It's not that big of a deal right now...I don't have the funds
