Old 04-03-2020, 06:26 PM   #1
337
Throttle return spring location and throttle rod fastener?
1970 c10 350 engine/350 turbo stock
4bbl Rochester
Looks like po did his own spring/rod mod to keep truck running.
How do I fix to get back to stock?
Throttle spring location/ setup
Looks like i need a dual spring mounted lower on the throttle bracket.
Then connect it to the coil bracket.
Would yall agree?
Do I need one on both sides of the carb?
Throttle rod fastener
Do I add some washers to tighten it up
and then just use a cotter pin or wire to secure it?
Trying to get to stock but not going for contest show points.
Pics of your stock 1970 Rochester may help.
337 is offline   Reply With Quote
Old 04-03-2020, 06:31 PM   #2
337
Re: Throttle return spring location and throttle rod fastener?
Extra pic
