Disc brake dust shield fitt
Will the factory Disc Brake dust shields fit when doing a “Drum to Disc” conversion?
I have a 70 C-10, with the factory 6-bolt hubs and I run pretty much everything factory standard suspension parts with American Racing “Outlaw II” wheels. I’m pretty sure the kit I’m getting doesn’t have them included. On a side note. How do they attach? Will the factory shields even fit onto a 6-bolt hub? Thanks in advance |
Re: Disc brake dust shield fitt
My conversion kit in bought from summit came with shields. They were not listed when I bought it so it was a good surprise for me. The kit I bought was CPP and it included everything even upper and lower ball joints and inner and outer tie rod ends.
![]() Join Date: Feb 2009
I didn't do a conversion. The spindles were dropped and the factory shields weren't quite right. I just bent the bottoms out a pinch and good as new.
For what it's worth mine were attached by; The dust shield mounts to a spindle using three 1/2" hex bolts and lock washers. The bolt threads are 5/16-18 x 7/8. The bolts are stamped "RSC".
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
