04-04-2020, 12:49 PM | #1 |
LS Oil Pans
Anyone running this pan? It looks like a nice kit with everything together.
https://www.summitracing.com/parts/nal-19212593 My 67 c10 has 5/7 drop and LQ9. The stock truck pan hangs down to low. So I am looking for a new pan. Thanks for the help. |
04-04-2020, 01:21 PM | #2 |
Re: LS Oil Pans
I have that pan, it seemed to be really high quality and it is above the crossmember so suits me well.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
04-04-2020, 01:59 PM | #3 |
Re: LS Oil Pans
That is the Hummer H2 pan, it is about an inch shallower than the standard truck pan. It depends on your mounts, but on my truck, it hangs down not quite 1/2" below the crossmember.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
04-04-2020, 04:22 PM | #4 | |
Re: LS Oil Pans
Should I order the CTS-V one? |
04-04-2020, 04:24 PM | #5 |
Re: LS Oil Pans
This F-body one seems a lot smaller. 5 qts of oil vs 6 qts
https://www.summitracing.com/parts/n...8771?rrec=true |
04-04-2020, 04:49 PM | #6 |
Re: LS Oil Pans
I'm running a fbody oil pan and its well above the bottom of the cross member.
04-04-2020, 06:47 PM | #7 |
Re: LS Oil Pans
The f body pan is a 5 1/2 quart pan, so only half quart less. It is a lot shallower, but the sump part is longer so you may have to move the engine back to clear the crossmember. Never used one in a truck so not positive on that though. The CTS-V pan is supposed to work really well, I believe its shorter than the Hummer pan, not as shallow as the f body, but has a shorter sump, more like a small block pan.
04-04-2020, 08:31 PM | #8 |
Re: LS Oil Pans
I guess it does hang a smidge lower than crossmember, it is higher than the control arms connections. I have dirty dingo sliders which I don’t recommend.
04-05-2020, 10:42 AM | #9 |
Re: LS Oil Pans
used a CTS-v pan on a bagged 67 with an 5.3 on dingo slider mounts and stock v8 engine towers and when placing a straight-edge on the bottom of the stock crossmember the CTS-v pan was dang near flush
04-05-2020, 12:34 PM | #10 | |
Re: LS Oil Pans
04-05-2020, 01:08 PM | #11 |
Re: LS Oil Pans
I make my own mounts, so I put the engine where I want it, which is basically the stock small block position. I use mechanical fans, so I center the fan in the fan shroud.
04-05-2020, 03:03 PM | #12 |
Re: LS Oil Pans
I have the CTSV pan on my 74 with slider mounts. Lots of room to move to motor forward from where I have it. It’s the best pan for truck hands down.
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
04-05-2020, 03:45 PM | #13 | |
Re: LS Oil Pans
The reason i used the dirty dingo sliders was I had a SBC & TH350 in the truck originally and wanted to use the TH350 & the original driveshaft (budgetary reasons ). Short version: wanted the trans to stay where it was & to do so I needed to slide the LS further back than the SBC to mate up. Hope that made sense. Last edited by Willie Makeit; 04-05-2020 at 08:31 PM. |
05-14-2020, 08:07 AM | #14 |
Re: LS Oil Pans
The fbody pan and the hummer pan works well with factory engine stands and the swap plates with the factory motor mounts.
05-14-2020, 08:56 AM | #15 |
Re: LS Oil Pans
My truck has the F-body pan with Dirty Dingo Sliders with the engine slid enough forward to fit the A/C compressor in the stock location. Plenty of room and the pan sits slightly above the cross member.
Hope I am not causing any problems by putting 6 quarts in it?! |
05-14-2020, 10:00 AM | #16 |
Re: LS Oil Pans
F-body pan too. Sits above cross member with sliding adjustable mounts. Worked out great.
05-16-2020, 11:46 AM | #17 |
Re: LS Oil Pans
This is of little help. I'm running the stock truck pan, it hangs about an 1" below the cross member. Adding a skid plate off the cross member. It's a 2 wheel drive truck.
05-24-2020, 08:54 AM | #18 |
Proud Vet that loves the USA
Re: LS Oil Pans
05-30-2020, 12:11 AM | #19 |
Re: LS Oil Pans
Where do you guys get your CTS-V pan's from? Part number?
05-30-2020, 08:42 AM | #20 |
Moderator
Re: LS Oil Pans
Part Number is 12631828
Best price right now is from http://www.improvedracing.com/oil-pa...1828-p-87.html Genuine GM is around $330. This pan replaces part numbers 19254632, 12605814, 12628451 and includes mounting bosses for Oil Cooler if needed. Hope this helps
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
05-30-2020, 09:42 PM | #21 |
Re: LS Oil Pans
Excellent! Thank you for the part number. I appreciate it.
I was also able to find it here: https://www.gmpartsdirect.com/oem-pa...l-pan-12631828 |
05-30-2020, 10:41 PM | #22 |
Re: LS Oil Pans
What else is needed if the CTSv pan is purchased? Gasket, what else?
05-31-2020, 10:15 AM | #23 | |
Moderator
Re: LS Oil Pans
Just be aware this item from GM Parts Direct is a special order item that will require additional processing time....read the text on the web page... You would also need to purchase the correct oil pickup tube.... https://www.gmpartsdirect.com/oem-pa...621299/?c=bT0x
05-31-2020, 01:29 PM | #24 |
Re: LS Oil Pans
What do y’all think of this pan from Speed Engineering? The dimensions on it seem smaller profile than the ctsv pan and it comes with all hardware and pickup tube, for a cheaper price.
05-31-2020, 04:19 PM | #25 | |
Moderator
Re: LS Oil Pans
