04-04-2020, 02:32 PM | #1 |
Coil too big for coil bracket, cant strew bolt in
350 4bbl, original
Anyone have this issue. I cant get the screw to reach to the other side of the bracket . I will start to deform the coil case if I were to actually get it to bolt in. Last edited by 337; 04-04-2020 at 03:14 PM. |
04-04-2020, 03:20 PM | #2 |
Re: Coil too big for coil bracket, cant strew bolt in
I assume your replacement coil is a slightly bigger diameter.?
I have seen that before Can you use a longer screw? Other options, swap out the coil for one that fits, or get a different bracket. ...or |
04-04-2020, 04:01 PM | #3 |
Thank you for confirming. It looks newer. Possibly by the po and he is no longer with us to give history. I knew there was something off. I am not worried about it going anywhere. It is firmly sitting in the bracket and not moving without the screw. I'll see what I can find when I head to hardware store.
04-04-2020, 04:59 PM | #4 |
I bought about 4 new coils until i found one that fit. And it was tight.
Spectra premium c624 fit the best |
04-05-2020, 11:59 AM | #5 |
Another option is an aftermarket bracket. That's what I ended up doing, I think it was less than $20.
Jim |
