04-04-2020, 09:22 PM | #1 |
Drum Brake Actuator Lever Help
Gents,
I won’t go deep into the specifics, but I had an awful experience with a shop trying to rebuild my rear end (which I think is out of a 1972 K20, it’s hard to tell given how many different vehicles my 67 was cobbled together from) and in the process they took apart my drum brakes and left me scrounging to reassemble them. I have almost everything back together but I don’t understand how the actuator lever and return spring are supposed to mount with respect to the adjuster lever. Can anyone help me with a diagram, because every diagram I’ve found online is for a different style of actuator/adjuster lever. Photos should be attached. -Cole
1967 GMC Stepside on a 1974 SWB 3/4 ton 4x4 frame U. of Washington Civil Engineering Class of 2016 |
04-04-2020, 10:08 PM | #2 |
Re: Drum Brake Actuator Lever Help
This might help..looks like your shoes are reversed or on backwards
04-05-2020, 12:03 AM | #3 |
The adjuster on the right in the pic goes to the LH side that you have pictured.
The “hole” in it slips over the tang near the adjuster, the “U” shaped other end straddles the lever further back and up, the spring against the shoe pushing it towards center. |
04-05-2020, 12:06 AM | #4 |
Found a pic but its Upside down
04-05-2020, 12:19 AM | #5 |
More pics. This is the right side from my C20 with coil springs and Eaton axle.
Jim |
04-05-2020, 04:11 AM | #6 |
Randy, that’s the style I’m looking for. Thank you so much!
