Transmission Oil Cooler Recommendations
Any recommendations on the size of transmission cooler you would want for a 72 k2500 (TH350) I use it a lot going up into the mountains and I see a lot on the various sites. Rectangular, square, long tubes. I didn't know if there was a rating that works best or a size. Any help with someone running one of these would be great.
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Transmission Oil Cooler Recommendations
Can't help you with the particulars -- I'm sure others will -- but I wanted to pass along some information that might be helpful.
I looked into these years ago, just never bought one. Somewhere I read that transmissions like for the fluid to be at a certain operating temperature. It's possible to cool the fluid too much, for instance if you plumb it through your existing radiator first and then through the auxiliary cooler before returning to the transmission. It was recommended to have the fluid go through the auxiliary cooler first, then through your existing radiator's cooler. The idea was the coolant would help bring the trans fluid up to temp if it was too cool, and at the same time, it would not cause the fluid to rise above recommended temps.
Old member
GM recommends to keep automatic's below 200 * anything over 200 start's breaking down the fluid. I run mine as mentioned aux cooler then stock.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I haven't done any towing but I use the biggest "flat plate" cooler I can fit in front of the radiator. B&M is what I'm currently using. Some would recommend running the trans fluid thru the radiator cooler also to manage the fluid temp.
![]() Join Date: Nov 2006
Stock, cant beat it
I BELIEVE IN JOHN 3:16 |
Check into swapping out the stock pan for a finned 1 with a temp port. U need to know how hot it’s getting before u add a cooler. Also change from regular fluid to synthetic. They are made to handle the heat better.U may not even need an auxiliary cooler once u know just how it’s running. Once u see how hot it’s actually getting then u can get a plate style with or without its own fan or go to an aluminum tube style with fins. These will mount along the frame. They are made to work with the stock radiator or they can b used stand alone.
with a deep pan it will hit the x member a little so it will need modded
#8 | |
Old member
Living in the south I haven't ever been worried about it running to cool.
![]() If your up north then yea you may need to worry about it in the winter. If you pull a trailer with it a lot it's a good idea but for just driving the radiator cooler should be just fine. Just remember the water temp is 180* are so, so you have a small margin of cooling to keep the recommended 200* for the trans temp. ![]() Quote:
Thanks everyone. I think I will keep it stock and add a deeper pan. I'm in alaska and it only summer for 3 months. Really 2 lol. I was worried about all the mountain driving i put this truck through heading up to my house. It runs great, no problems, I just didn't want to start a problem if I could have just added something to help it. I will do the above to see what the temp is running at now. Thanks for all the thoughts. Appreciate it.
