Door Glass
This weekend the Glass on the passenger side door came loose from the frame. It appears the adhesive is just old and dried out.
I ordered Item 18 (38-5932 Glass Setting Rubber) in the photo. how hard will this be to reset the glass? |
![]() Join Date: Jan 2001
Re: Door Glass
Setting the glass isn't hard. Use a wire brush to clean the channel. Fold the rubber over the edge of the glass and spray some glass cleaner on it for lubrication. Use a rubber mallet to tap the channel onto the glass.
If you do a search, someone on the board did an excellent write-up on door reassembly. Edit: Here's that write-up: http://www.67-72chevytrucks.com/vboa...ight=door+easy
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson Last edited by truckster; 04-06-2020 at 09:27 AM. |
![]() Join Date: Aug 2018
Re: Door Glass
I bought same setting rubber but instead used 3M windshield urethane. I didn't like the idea of friction holding the glass in and I was skeptical of it because one of my door glasses came out of the channel pretty easy during disassembly. The windshield urethane isn't hard to work with, just heat it up and work fast because it starts drying pretty quick. But with the urethane it creates a bond. I masked off the glass and the channels so it didn't ooze out everywhere when you put the glass in. Then used a couple bar clamps to hold them in place for the day. If you don't have bar clamps you can use ratchet straps too.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
Re: Door Glass
Where did you purchase this, Homes Depot?
That is my concern as well. |
Re: Door Glass
Most modern door glass is set with epoxy. You can get urethane windshield adhesive at most auto parts stores. JB Kwik Weld is the epoxy I recommend. Use a couple of cardboard spacers at either end of the channel to make sure there's some space between the glass and the metal - a strip 1/4" wide will work. Just fold it and put one in each end of the channel before you glue in the glass. The advantage of doing it this way is that you can do it with the channel installed in the door.
Just be aware that if you ever break the door glass it's going to be a bear to get the channel clean.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Re: Door Glass
Truckster has a good point, it will be difficult to get that channel cleaned out if you fill it with epoxy.
I bought it off Amazon https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
