Old 04-06-2020, 09:35 AM   #1
cgster
Sending unit ground wire
Trying to put my truck together and it has no wires at all going to the gas tank. I was going to order the wire that goes from the fuse box to the tank itself. My question is, where do you have the ground wire on your gas tank/cab?
cgster is offline   Reply With Quote
Old 04-06-2020, 09:52 AM   #2
Brentwe
Re: Sending unit ground wire
Perhaps you mis spoke with the fuse panel. It's my understanding that on the tank, Ground lug is connected to any good chassis or body ground location. Sender lug is connected to guage, power wire is connected to other side of guage. There should be no power going to tank.
Not knowing what you have, perhaps you have an in tank fuel pump.
Brent W
66 short step
4 x 4
Brentwe is offline   Reply With Quote
Old 04-06-2020, 09:59 AM   #3
cgster
I thought a wire ran from the fuse box panel to the sending unit stub that goes into gas tank, and then a ground wire ran somewhere from the tank to the cab...but I could be wrong.
Old 04-06-2020, 10:16 AM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: Sending unit ground wire
Correct you are sir. Your tank needs a good ground and most stock tanks ground by the bolts holding it in place to the cab back wall. But adding one is not a bad idea. The tan wire runs from the fuse block to the tank and attaches to the sender. Save the picture and blow it up to trace the wiring.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-06-2020, 10:20 AM   #5
cgster
Good, thanks for the info Andy!
Old 04-06-2020, 10:25 AM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Sending unit ground wire
Welcome sir!
Old 04-06-2020, 10:37 AM   #7
Brentwe
Well apparently I'm quite wrong on this, glad you got the right stuff, wiring diagram to boot.
Brent W
66 short step
4 x 4
Old 04-06-2020, 11:46 AM   #8
LockDoc
The Older Generation
LockDoc's Avatar
Here are some large wiring diagram image files.
http://67-72chevytrucks.com/vboard/s...d.php?t=185856
Below the small wiring diagrams you will see links to the larger diagrams, click on those.
The wiring shown for the windshield wipers is wrong on those diagrams so you will have to look at the image in post #67 (on page 3) of this thread for the correct wire color and plug orientation for the wiper/washer.
http://67-72chevytrucks.com/vboard/s...d.php?t=413551
LockDoc
Leon
Old 04-06-2020, 12:06 PM   #9
maverickmk
maverickmk's Avatar
LockDoc
These wiring diagrams have become invaluable to me.
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 04-06-2020, 10:06 PM   #10
kaycee
kaycee's Avatar
Service manuals are great tool to have
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
