68 c10
I am changing out the original three pod gauge cluster to a seven pod cluster, any reason the fuel gauge wouldn't work on the new gauge cluster? should be just an unplug replug thing but not in my case. Am I missing an adapter for it to read? Gas tank is traditional in cab tank. Any assistance would be appreciated. Thanks in advance,
Re: 68 c10
I wish I could help here but.... my only thoughts are to
1) verify grounds... 2) install the old fuel gauge in the new cluster and see if it works again, if so maybe just paint the needle and call it done?
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 68 c10
This is a good thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=645940
