Old 04-06-2020, 11:31 AM   #1
cebra
Trailing Arm Bushing - Hole Saw?
I have a ton of time to work on the truck now so I am doing all the projects I have been meaning to for months. Anyways, next up is replacing the trailing arm bushings. Rather than drill or burn them out, has anyone ever tried to use a hole saw larger than the inner sleeve but smaller than the outer sleeve to cut the rubber out?
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 04-06-2020, 03:16 PM   #2
68Gold/white
Re: Trailing Arm Bushing - Hole Saw?
Hole saw might work. A sawzall might work too. I have used an air chisel (muffler gun) with a blunt end and smash the outer shell inwards, compressing it, allowing it to be driven out easily.
68Gold/white is offline   Reply With Quote
Old 04-06-2020, 05:41 PM   #3
KMC3420
KMC3420's Avatar
I used a drill bit barely smaller than the rubber itself and drilled the rubber multiple times to weaken it. It comes out really easy doing this. I imagine the same effect would happen with the hole saw, but it’s a 5 minute job with a drill and drill bit. Then just drive out the metal bushing with a hammer and then the rubber all but falls out.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 04-07-2020, 07:46 AM   #4
cebra
I think the drilling is the standard but I have seen folks drill like 20 holes in each side so was thinking the hole saw may do the same thing quicker. So you only had to drill a few holes in each side to get it out, may be simpler to go with the tried and true but I may give the hole saw a whirl if I have the correct size on hand.
Old 04-07-2020, 08:49 AM   #5
67C10Step
67C10Step's Avatar
I did the old school heat it with a simple bottle torch and squish the center out. Only took about 10 minutes to get the center and rubber out, the outside shell was a different story.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 04-07-2020, 09:37 AM   #6
hayhauler71
hayhauler71's Avatar
ball joint press will push them right out
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 04-07-2020, 10:53 AM   #7
68Gold/white
LOL, I can smell the rubber burning, NOW!!!
Old 04-07-2020, 11:12 AM   #8
KMC3420
KMC3420's Avatar
Yeah, I did maybe 6-8 holes, then knocked the metal bushing out. The hole saw would work as well, if the hole saw bit is long enough to go all the way through. The rubber in mine was pretty weak.
This link has some pictures at the bottom.
Trailing arm bushing thread
Keagan
Old 04-07-2020, 11:47 AM   #9
67C10Step
67C10Step's Avatar
You know it! Reminded me of this line from a very good song: "You could smell the whiskey burning down copperhead road."
Cebra - you got them things out yet? If so, what was your method?
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 04-07-2020, 02:09 PM   #10
HO455
Post Whore
HO455's Avatar
Are you asking how to remove the bushing from the arm or how to remove the inner sleeve from the bushing?
RIP Bob Parks.
