Lowering shackles???
I helped a friend buy a 71 C-10, it has rear leafs. Anyone make shackles that are taller, to lower???
![]() Join Date: Aug 2018
Re: Lowering shackles???
DJM Suspension makes them. But they will require notching a cross sill on your bed to provide clearance for the spring. How much lowering is your friend looking for?
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
Not looking for anything big lowering wise. He is a good friend, he and I think alike on these classics, a mostly stock look, a little lower is nice, but not slammed or on the ground.
The rear of this pickup sits a little higher than the front. The stock shackles are about 4-5 inches between the shackle bolts, looks like there's about 4-5 inches between the top of the stock shackle and the bed floor. |
My truck came with lowering shackles and I put them on but found out that the bed floor touched the shackle before the bed floor could come to rest on the frame. I don't know why it happened for me, I've never heard of that happening to anyone else. I have heard of having to notch the cross sill though for the leaves. This resulted in 2" of drop.
So I put the stock shackles back on and put on lowering leaf springs (a little pricey) and ended up getting just over 3". I had the HD leaves. I expected to get more than 4", but I guess the springs sagged over time. It's all a little unpredictable it seems as springs sag over time and not all trucks had the same springs/ride height. If I were you, I would ask DJM for the eye to eye length on their shackles so you can decide if they will work or not before ordering.
Shackle least expensive and MIGHT get you 2". More like an 1 1/2". Great for leveling a truck with stock springs in the front.
Next cheapest is a flip kit. DJM the source again. On my truck netted 7 1/4" drop. Too much for some. Reality is the only way to get something between 1 1/2" and 7" is to buy springs. I would buy a set of springs that were right at or just less than the drop you want, then keep the shackles in your back packet to get just a little bit more if you need to fine tune ride height.
I looked at the DJM website. Their lowering shackle says it will lower your truck, 2 inches.
He is not ready for this work yet. I WILL call them to find out what the distance is between the mounting bolts. The picture of their shackle has 2 sets of holes in one end... |
