Old 04-07-2020, 03:06 PM   #1
DennisP
DennisP's Avatar
Leaking proportioning valve
My proportioning valve has developed a leak around the little rubber boot that covers the valve on the end of the prop. cylinder block.
This came about after I changed the front brake pads.
Is this something I can fix with a new O ring or something? I don't know too much about how these things work.
DennisP is offline   Reply With Quote
Old 04-07-2020, 04:41 PM   #2
randy500
Re: Leaking proportioning valve
Aftermarket brass? They always leak
randy500 is offline   Reply With Quote
Old 04-07-2020, 05:27 PM   #3
RichardJ
Start here.
https://www.musclecarresearch.com/gm-1257208-rebuild
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 04-07-2020, 08:28 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Leaking proportioning valve
Do yourself a favor and get one without the rubber boot. I had one and it blew out coming up to a stop sign with no warning!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-07-2020, 10:08 PM   #5
DennisP
DennisP's Avatar
Ok, now you got me officially worried.!
Old 04-07-2020, 11:28 PM   #6
DennisP
DennisP's Avatar
Yes it is aftermarket brass. Solution? Replace brass end, or the whole thing?
Old 04-07-2020, 11:53 PM   #7
randy500
Call CPP tell them its their valve and you bought it from a vendor, make one up. They will send you a seal kit.
Take it apart and Figure out whats wrong with it, there must be a burr or some defect causing them to leak.
Old 04-08-2020, 08:34 AM   #8
Andy4639
Old member
Andy4639's Avatar
Look for one that doesn't have the button. Good insurance.
Old 04-08-2020, 01:45 PM   #9
DennisP
DennisP's Avatar
Thanks for that randy500. Lucky for me CPP is less than three miles from me.
Bad luck is that it'll have to wait as they are closed due to the virus thing.
