Old 04-08-2020, 12:52 PM   #1
demian5
demian5's Avatar
1983 Tailgate window motor
Anyone know if the motor from my truck (that bolts to the regulator directly) is the same as any of the door window motors?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 04-08-2020, 02:43 PM   #2
Ski-me
Ski-me's Avatar
Re: 1983 Tailgate window motor
No, I don't think so. The one in the tailgate is driven by a cable, similar to the Speedo cable, with a square end. Black one is tailgate. Silver one is window regulator motor.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 04-08-2020, 07:48 PM   #3
demian5
demian5's Avatar
Please read my post again, it bolts to the regulator. I unbolted it myself, hence my thoughts that it would swap with a window motor.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 04-08-2020, 10:34 PM   #4
Irish1941
Irish1941's Avatar
It does not interchange with door motors.
What ski-me said is correct.
They are self contained drive motor that spin a cable. Always have been.
What you have done is unbolted the transmission gear NOT the motor from the regulator. Follow the cable and you'll find the motor.
Edit:
You left out part it's a Suburban. Had to guess that from your sig.
No they still don't interchange with the doors.
https://www.oreillyauto.com/detail/b...ow+motor&pos=0
Irish1941 is offline   Reply With Quote
Old 04-09-2020, 07:10 PM   #5
demian5
demian5's Avatar
Yeah I guess Suburban and Blazer are different.
Here is the motor. The plate is on over the gear in this picture, I put it back on so as to not lose anything.
I have a spare regulator that is cable driven, so I understand the difference.
I can get a picture of the regulator too, but I feel this is also a window motor...
How about this question instead "What window motor is this? LF, LR, RF, RR?"
And here it shows what I have, in the LMC catalog.
https://www.lmctruck.com/1973-91-che...nents-suburban
1986 C20 Scottsdale
Instagram: C10sofOC
Old 04-09-2020, 08:16 PM   #6
Irish1941
Irish1941's Avatar
Let me try again...
There is NO interchange. It is NOT a door window motor.
LMC link shows a Sub tailgate window motor. Notice how it's not highlighted?
That means there is no interchange. Nothing replaces it except Sub tailgate window motor and drive.
If it was a door window motor, they'd sell you one in a heartbeat.
I'm not even going to bother with GM part numbers because there is only one.
Look up at ski-me's photos again.
That black rectangle box...that's the K5 motor. The Subs look the same as K5 motors but they can't be separated for replacement. Siiver one is what door motor units look like.
Undo those top 4 bolts off yours and the windings come out.
Sub tailgate replaces as entire unit. Just as door window motors replace as entire unit, which are completely different.
I've parted out over 150 Subs, Blazer and Jimmy in last 35 yrs. so this isn't first time I've had to explain this. Kinda like the Blazer and Sub tailgate glass isn't the same.
Old 04-09-2020, 08:42 PM   #7
Irish1941
Irish1941's Avatar
And just noticed looking your pix, the gear drive is totally wasted.
Should be a gear on the shaft from the drive transmission.
You may only need the gear
Old 04-10-2020, 12:13 PM   #8
demian5
demian5's Avatar
Being that I have the plate over the gear, cant see the gear drive. Have you had success pulling the motor off and cleaning it up? Or do you have any good ones? Id be willing to barter the k5 regulator I have for one.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 04-13-2020, 06:50 PM   #9
Irish1941
Irish1941's Avatar
Slow reply but I looked but just have a few of the cable version left.
A little info for you to make your search easier.
-'84 is last yr for this style of motor.
-GM station wagons from 68-75 use same motor in tailgate.
-Some passenger cars used motor in doors as well. Think to about '75 or so as well. Not trucks though.
Here are some interchange GM numbers.
5045561, 5045585, 5045587, 5045589, 5045591,
5045594, 5045609
Old 04-14-2020, 12:31 PM   #10
demian5
demian5's Avatar
5045594, 5045609
Solid info my man! Thank you.
Rock auto sells a cardone for $80 for a 75 caprice door.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 11-09-2020, 09:38 PM   #11
mcrich65
Let me try again...
Would you happen to still have a tailgate motor I need one for my 89 suburban.
mcrich65 is offline   Reply With Quote
Old 11-11-2020, 02:04 PM   #12
Irish1941
Irish1941's Avatar
If I have one, you can have it for price of postage.
I'll check later in the week for you.
Old 11-13-2020, 04:42 PM   #13
mcrich65
