Old 04-08-2020, 05:14 PM   #1
YourBuddy'sTruck
YourBuddy'sTruck's Avatar
TH350 Troubles / Questions
Having trouble with my TH350.
1970 C20, 350cc, Th350.
Here's the story.....
Started leaking out of the pan over the Winter.
Drained fluid, pulled pan, new seal, then refill with new fluid.
Ran fine, everything okay.
I don't use it much in the winter...literally 100 miles or so the whole winter.
As we've warmed up, I'm driving it more and now the transmission seems to be slipping.
A little at first, now it's quite a bit of RPMs till it finally shifts and gets up to speed.
Once up to speed, seems fine.
The fluid I put in is Dexron-VI / Mercon LV.
(I don't even know what these words mean, but that's the one most of you here suggested in threads)
Did I do something wrong? Or is this thing in need of new friction rings and a rebuild?
Any help / advice would be appreciated as I know just about nothing on Transmissions.
Thanks in advance.
Also, last year I replaced the Actuator (vacuum shift) Valve with your help, as well as the Speedometer Cable and Gear.
YourBuddy'sTruck is offline   Reply With Quote
Old 04-08-2020, 06:29 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: TH350 Troubles / Questions
If my TH350 gets low on fluid, say one pint or more, it will sometimes slip when first starting to move the truck. RPM increases momentarily, then it hooks up and you're off.
I don't know if that's similar to your situation, but it's easy to check fluid level. Make sure the trans is fully warmed up, truck on a level surface, idling in Neutral or Park (I don't think it makes a difference with these trucks).
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 04-08-2020, 07:36 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
Sounds like either:
1/ Low fluid level: Start truck, park brake on, trans in Park...place trans in D, then N, then R, than back to Park. Engine running, check fluid level on dipstick. Cold it must be above lower level mark, Hot it can be at upper level mark.
2/ Vacuum leak at modulator pipe: Check the rubber tube at top and bottom of the vacuum modulator pipe to ensure there are no splits or cracks.
3/ Hard clutch seals: If the trans has never been overhauled, the clutch pack seals tend to go hard. The clutch seals need to seal correctly for a shift to occur. If the issue "goes away" once the trans has warmed up, and the oil level is correct, I would be looking at either having this trans overhauled or exchanged for a rebuilt unit.
You mentioned the vacuum canister...more correctly known as vacuum modulator,...
Was it replaced due to a leaking trans fluid into the engine ?
Did you replace the filter in the trans when you had the pan off?
Some of these modulators, have an adjustable feature to fine tune shift points. However, most of the described issues seem to point to one of the three items I listed above.
Hope this helps...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 04-08-2020, 09:31 PM   #4
YourBuddy'sTruck
I did not replace the filter. Thought I was just fixing a leak?
I'll recheck the fluid after running it some tomorrow.
Also look for vacuum leaks.
Yes, it was pulling fluid into the engine and smoking out the passenger exhaust.
but come to think of it, that was two years ago.
I actually plan on overhauling the whole engine and transmission, just keep putting it off because of life and best laid plans and all that.
I'm not afraid to tackle any job, just limited on time to devote.
That said, I'll hope it is one of the easy solutions!
Thanks fellas!
Old 04-10-2020, 04:55 PM   #5
YourBuddy'sTruck
Still slipping.
I topped off the fluid. (less than a pint)
Shifted while holding brake and rechecked fluid level. Good to go.
Went for a test drive and still slipping.
Pulled into an empty parking lot and came to a full stop and put it in reverse.
Strange? It totally performs in Reverse?
Put it in Drive and slipping. Reverse again and it performs fine?
What would this make you think is going on? I'm really confused now.
Old 04-10-2020, 08:57 PM   #6
AussieinNC
Moderator
AussieinNC's Avatar
Originally Posted by YourBuddy'sTruck View Post
Still slipping.
The forward clutch pack is toast...time for an overhaul....
Time maybe to consider an upgrade to maybe an overdrive trans...
2012 Chevy Equinox
Old 04-11-2020, 09:01 AM   #7
Bigdav160
Bigdav160's Avatar
I think the two most commonly mis-used words in the automotive lexicon are "slipping" and "hesitation".
What they mean to a technician and what they mean to a vehicle driver are usually two different things.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-11-2020, 09:22 AM   #8
YourBuddy'sTruck
This is some obvious slipping.
Lots of RPMs and no go.
Regardless...looks like I'll be reading every thread here on TH350 rebuilding!
Thanks for the replies and sending me in the right direction.
Old 04-11-2020, 11:37 AM   #9
54blackhornet
54blackhornet's Avatar
My 71 GMC with a 350 sat for twenty years. When I first tried to drive it I was surprised to find absolutely no fluid showing on the transmission dip stick. I filled it up with Dextron. It moved but slipped when you first gave it gas. I had the filter replaced and refilled it with Ford type fluid. Now it operates perfectly.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 04-11-2020, 12:07 PM   #10
67swb72klb
67swb72klb's Avatar
Used turbo 350 are pretty cheap these days you may find a great deal on a fresh one..
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is online now   Reply With Quote
Old 04-11-2020, 02:36 PM   #11
68bbc/20
I need to put a new gasket and filter on my 350 turbo also, will the pan clear the crossmember in the back and drop down or do I need to unbolt the crossmember and mount to move it out of the way?
68bbc/20 is offline   Reply With Quote
Old 04-11-2020, 04:20 PM   #12
54blackhornet
I didn’t have to.
71 C-20
07 Magnum RT AWD
Old 04-11-2020, 07:39 PM   #13
Daron65
I may be asking this incorrectly, but what should be the shift points be?
1971 Chevrolet C20, Blueprint 355. Holly Street Avenger 430HP. Turbo 350
1952 Chevrolet Deluxe. Stock. True survivor with 1 paint job
1953 Buick Special. GM 355. Just a good smooth engine.
Daron65 is offline   Reply With Quote
Old 04-12-2020, 01:13 AM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Depends on how light or heavy your right foot is, among other things. My K20 is virtually stock and with the loud pedal pinned, it shifts at 4500 RPM.
- Mike -
RIP El Jay
Old 04-12-2020, 08:45 AM   #15
Bigdav160
Bigdav160's Avatar
This sounds like a late shifting problem. I know Aussie is a good tech (I was Chevrolet Master myself) but you wouldn't get up to speed with a forward clutch slipping. In third you are using direct and forward clutches. Direct are used in reverse also so a solid reverse doesn't indicate a problem with that clutch.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 04-28-2020, 04:57 PM   #16
YourBuddy'sTruck
Thanks for all the replies fellas.
I'm pulling everything.
Started a new thread to ask about pulling the Transmission and such.
This one is a c20 with the 2 Drive Shaft Set up.
So I pulled the Shafts and all.
This, so I can get new Universals while at it because...whey not?
Learning this stuff is mostly fun with some swearing, but when finished, I'll know it was done right.
Also, to answer one of you, the C20 with 2 Drive Shafts has a massive Cross Member that is right in the way to remove the rear drain pan bolts.
Looks like the same Engineer at GM designed that AND the amount of clearance for holding the bolt to remove said Cross Member. That fella was EVIL!
