Old 04-08-2020, 06:14 PM   #1
mike1971c10
mike1971c10's Avatar
auto trans linkage
Hey guys, I could use your help. I have a 71 c10 with 75 c10 running gear. It's a 350 with 350 transmission. What I'm looking for is a picture of the linkage from the column to the transmission. What I have does not look at all like what is on a 67-72. Here are two pictures if it helps.
thank you
mike
my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522167 vietnam vet 67-68
mike1971c10 is offline   Reply With Quote
Old 04-08-2020, 08:00 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: auto trans linkage
That look's like most 73- up GM's.
The second pic is the pivot arm mount to the frame the other pivot @ trans goes up to rod that locks the trans in park. You will need steering column 73 -83 up GM TRUCK to make use out of the lock out rod after 84 the wiper switch is on the column and the high beam is on the column too. So you have to see options you need you may want to up grade to one you must have to work the dash set or setting up to work with your build.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 04-09-2020, 02:16 PM   #3
Dead Parrot
Here are some picts from my 75 w/TH350. Tilt column. Can get shots of the bottom parts once I get the truck into the shop to inspect the driver's fuel tank.
Dead Parrot is offline   Reply With Quote
Old 04-09-2020, 04:01 PM   #4
mike1971c10
Thanks guys, that's what I have in my 71 c10. ( blue one in avatar)There is nothing wrong with it, I just needed to see what I have.
thanks again
mike
