Rust Treatment...whats Best??????????
GOT A COUPLE LITTLE SHOTS ON THECAB FLOOR............
so before i put in the new carpet...what should i do....????? it's not a show truck... but i would like to stop the rust dead in it's tracks ![]() |
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
this is all i got pa
Sorry, this site is temporarily unavailable! The web site you are trying to access has exceeded its allocated data transfer. Visit our help area for more information. Access to this site will be restored within an hour. Please try again later. http://www.geocities.com/goodytommy/rust/ Need extra data transfer? Sign up for GeoCities Pro or Webmaster. Learn more. |
I used "Extend" but is now "Permatex Rust Treatment". I put a few coats on, then primer over. It has been about 2 years and no problems as yet.
1969 GMC S/B S/S 3" drop |
If you are talking about just a couple of spots of rust under the carpet then I would just scrape it and paint it. The best thing to do when you see the first signs of that is to make sure you don't have water intrusion into the cab. Reseal your windows, doors, make sure you don't have a leak from the drip rail, cowl etc. Stop it now before it gets worse.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
when i started on my pickup an old man gave me some great information. plastic roof cement. absolutely amazing. grind the rust off, and coat this goooo on. i used it on the tob and bottom of my cab floor and a year later it looks beatiful still, had to drill through it to install new seats. i love it. i love it enought to use on my dads 66 dodge crew cab project. good luck, Ben
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
Get rid of the rust most importantly! Squrit some primer andsome rust'oum and before the carpet goes in, dayna mat the floor.
![]() ![]() Join Date: Jan 2002
Grind the rust off then put por 15 on it.
Almost Satisfied
![]() Join Date: Mar 2002
In my last issue of Auto Restorer they did a comparison of rust preventers and the Eastwood product was rated the best over POR15.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
