Ebay Junky
Por-15, steps + where to spray?
i was thinking about purchasing some por 15 for my truck. my question is where should i spray it? i want my truck to be very solid as i am going to drive it all year long even during the winter. Also what prep work do you have to do before you spray it?
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain.. 1983 Chevy c10 swb 2wd - possible 350tbi supercharged... |
I have never sprayed it but from an earlier thread don't get it on your thingy, or was that the bedliner stuff?
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
If you spray it, wear protective clothing. It will not wash off! There is even a warning on the can that says if you get it on you, only time will take it off. It stayed on my buddy for three weeks!
I sprayed the whole underside of a k-5 blazer with it. Man that was a mess my resporator was ruint after but it turned out well.
p.s. use a resporator that stuff is toxic when air borne
The very atmosphere of firearms everywhere restrains evil interference. When firearms go, all goes, we need them every hour. - George Washington No free man shall be debarred the use of arms - Thomas Jefferson Later Darren ![]() http://www.myspace.com/dmurphy68 |
its all about the +6 inches
yeah...don't get any on your thingey.
We won't talk about that one right now. ![]() |
chevelito
I brushed mine on. It's thick enough out of the can that it will spread out. ...and dont even get it close to your thingy...youll be stroking it for weeks trying to get it off....lol.
jay
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
#7 | |
your buddy? meaning uhh, yeah. Like he said. No matter WHAT you get it on, it don't come off! Prep Prep Prep. Do alot of research on their website, It should tell you pretty much everything you need to know. www.por15.com
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
user # 2756
![]() Join Date: Jun 2001
I think it needs to be said that the idiot that got it on his thingy was on an ferd exploder form.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
Ebay Junky
so you dont have to have a spray gun to apply it? can you just take it out of the can and kind of spread it on? how long does it take for this stuff to dry?
![]() Join Date: Feb 2000
POR-15 works real good but it takes a lot of time to do it. It is a 3 step process.
1st clean using POR's Marine Clean, Then Spray it with Metal Ready, keeping wet for 20 min. Rinse with water, dry. Then apply the POR-15. Be prepared to spend the weekend doing it. They sale a kit for Floor Pans & Trunks that has everything you should need. |
chevelito
I only use metal ready if I dont plan on painting for a couple of weeks. then I sand it down again to get that white crud off for paint. It usually dries in 24 hours. buy small cans of the stuff because the shelf life, after you open it, is really short
#12 | |
#13 | |
Don't say "Oops!", Doctor
'Mutt 1968 CST LWB: R.I.P. 1967 Chevelle: TPI 454 beast 1967 C10 SWB: Claimed when Bumpster didn't put it on his list |
#14 |
drag racer
hootus
Don't get any POR-15 on your hootus
Current rides: 01 GMC 2500 SB HD CC 4x4 8.1 allison 67 Chevelle drag car 516 CI BBC,TH400 9.777 @ 138.4 mph 1970 C10 2WD PU being rebuilt 1967 El Camino 502, TH400 ( wife's drag car) Jr. Dragster 5 hp B&S for the kids |
#15 |
I spray mine on, but the guys at POR15 will try and talk you out of it. You will waste some obviously by spraying it, but I think the finish is better. And whatever you do, make sure you are covered from head to toe because it will not come off. I ruined a pair of contacts and had black hands....lol
They say it is like powder coat in a can and I think I believe it. |
#16 |
That was the word:
HOOTUS!!!!
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
