Old 04-11-2020, 07:43 AM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Where does this bracket attach? 71 manual throttle
I’ve searched the FAM and combed old related posts but cannot find any guidance on where the small bracket specific to the 71 manual throttle option bolts to. Any guidance and photos would be a big help. Thanks.
Old 04-11-2020, 08:47 AM   #2
71 super
71 super's Avatar
Re: Where does this bracket attach? 71 manual throttle
I will have to look, but if not mistaken, it bolts on throttle bracketand catches the cable as it moves to pedal extension. If I remember correctly it catches one of the three hole at top of main bracket
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 04-11-2020, 09:48 AM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks. The holes on the throttle bracket seem to small to accommodate the accompanying bolt but that arrangement seems sensible. Pics if possible please.
Old 04-11-2020, 12:06 PM   #4
randy500
It bolts to the brake pedal assembly, forward bolt i think, or above it, someplace on it in that area.
http://67-72chevytrucks.com/vboard/s...d.php?t=783035
randy500 is offline   Reply With Quote
Old 04-11-2020, 03:06 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks Randy. I’m surprised there’s no previously posted detail pic of where the small bracket mounts let alone showing the routing between the ducts for 71 as the mount is shifted sideways much more than the 72 example.
Old 04-11-2020, 03:29 PM   #6
randy500
There is a factory assembly manual type drawing out there of how it fits together, i cant find it now though.
I also looked at my pedal assembly and cant figure out how it mounts.
I bet classic bowties knows how it mounts and has pictures.
Old 04-11-2020, 03:32 PM   #7
randy500
I bet you have to drill a hole like you have to drill a hole in the brake pedal for cruise control vacuum switch on the pedal.
Old 04-11-2020, 04:01 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Doh! Am hoping it’s just a straight forward bolt in.
Old 04-11-2020, 05:26 PM   #9
FirstOwner69
FirstOwner69's Avatar
Info from long ago... May help. Read another regarding cable routing over the wiper motor and down.
Start at post 59.
https://67-72chevytrucks.com/vboard/...hrottle&page=3
Jim
FirstOwner69 is offline   Reply With Quote
Old 04-11-2020, 07:36 PM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Jim thanks. Almost. I’ve got same question as badpeanut but don’t see it was addressed on that thread (https://67-72chevytrucks.com/vboard/...3&postcount=61).
Old 04-11-2020, 09:58 PM   #11
FirstOwner69
I figured that would be the case but was hoping you would spot the piece in the photo in post 59 even though I couldn't.
Jim
Old 04-11-2020, 10:11 PM   #12
FirstOwner69
It's not the piece I marked below, is it?
Jim
Old 04-11-2020, 10:20 PM   #13
DeadheadNM
Carpe manana
DeadheadNM's Avatar
It’s not. That part of the larger bracket. The smaller one I suspect is just outside the field of view but the picture does show the trajectory of the throttle cable as it “lands” on the pedal and gives a clue. It’s got to be on the brake pedal assembly as Randy mentioned but a photo clarifying orientation would be helpful.
Old 04-11-2020, 10:57 PM   #14
FirstOwner69
The pictures in this link may provide a clue. They show that bracket attached to the cable. That bracket must attach to something above. Could be the brake pedal assembly as you suggest.
http://67-72chevytrucks.com/vboard/s...17&postcount=5
Jim
Old 04-12-2020, 12:39 AM   #15
FirstOwner69
Info on cable routing. A bit "hazy" though.
http://67-72chevytrucks.com/vboard/s...9&postcount=14
Jim
Old 04-12-2020, 07:35 AM   #16
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I saw those, thanks. Definitely helpful. The cable routing shown in the second link is straightforward and makes sense for the 72 design. For 71, the cable I suspect courses left of the washer pump as it meets the pedal several inches to the left relative to that for 72. Still hoping someone with a 71 setup can post pics showing bracket and cable location.
Mels post is the one got educated me that a difference existed for 71 vs 72.
Old 04-13-2020, 12:33 PM   #17
JT_Trucks87
JT_Trucks87's Avatar
Just another example of routing with the little bracket on the 1971 setup.
1987 V30 Silverado SRW 454/400 4x4 104k
1979 GMC C3500 Sierra Classic 3+3 454/4l80e
1971 K20 Cheyenne
http://67-72chevytrucks.com/vboard/s...d.php?t=804580
https://67-72chevytrucks.com/vboard/...d.php?t=837441
https://67-72chevytrucks.com/vboard/...92#post9355392
JT_Trucks87 is offline   Reply With Quote
Old 04-13-2020, 04:09 PM   #18
DeadheadNM
Carpe manana
DeadheadNM's Avatar
That's it! The missing piece. Thank you sir. I bet the cable runs left of the wiper motor not right of the motor as for 72.
Old 04-13-2020, 04:46 PM   #19
randy500
Finally a picture.
Just as i thought, requires drilling.
Now the question is, do both holes on the bracket get a bolt or just the one pictured.
Old 04-13-2020, 04:55 PM   #20
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The visible bolt is an existing one on the pedal bracket isn't it?
FWIW several I've seen offered for sale over the years have a bolt at each hole.
Old 04-13-2020, 05:58 PM   #21
randy500
I only have 72’s here, checked 3 and none have a hole for either location.
Old 04-13-2020, 06:00 PM   #22
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I peeked updash in my Blazer last night - may have mistook a bolt for the one here. Will look again.
