Old 04-11-2020, 11:39 AM   #1
ccautoupholstery
Air intake
I'm just curious what everyone is using for air intake on their swap. My 5.3 is out of an 01 suburban and had a K&N setup but it doesnt fit quite right in my 67 obviously. I relocated my battery to the drivers side so wanting to keep it going to the passenger side and reuse my filter. Are there kits for the ductwork?
ccautoupholstery is offline   Reply With Quote
Old 04-11-2020, 04:33 PM   #2
LS short box
Re: Air intake
I've bought from WWW.intaketube.com. Both metal sections (alum and steel) along with rubber sections. He also has rubber reducer hoses.
LS short box is offline   Reply With Quote
Old 04-11-2020, 04:36 PM   #3
LS short box
Re: Air intake
Sorry gave you bad info. Should be www.intakehoses.com. They are in Spokane WA.
Old 04-11-2020, 05:08 PM   #4
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Air intake
I got the aluminum tube off ebay and used spectre fittings to make mine
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-11-2020, 10:57 PM   #5
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: Air intake
I bought my air intake from Pacific Fabrication / Tilden Motorsports. It's nice, but it took a little tweaking to get it to line up right. It's designed to mount to the stock alternator accessory drive. Let's me keep my battery in the stock location.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 04-12-2020, 01:03 PM   #6
flashed
Re: Air intake
derotoreut , do you have a link to that ?
flashed is offline   Reply With Quote
Old 04-12-2020, 10:01 PM   #7
thehata1
Re: Air intake
Subscribing for a link that intake!
thehata1 is offline   Reply With Quote
Old 04-13-2020, 01:36 PM   #8
First c10
First c10's Avatar
Re: Air intake
I ordered from
http://www.siliconeintakes.com/
This was mock up. Filters will go where the bubble wrap is! Unless I change which is a possibility....
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-13-2020, 05:37 PM   #9
derotoreut
derotoreut's Avatar
Re: Air intake
There is no link to it as it's not on their website. You'd have to give them a call @ 408-600-0122. Ask them for their direct fit air intake for 63-72 Chevy trucks for LS swaps. Remember it is made to use the stock accessory drive. I listed their websites below, but they are really one in the same.
The Tilden website is: http://tildenmotorsports.com/
The Pacific Fabrication website is: http://pacificfabrication.com/
~ Dan
Old 04-17-2020, 10:09 AM   #10
paul mora
Re: Air intake
What radiator are you using and where is your upper hose connection
Pulatoy
paul mora is offline   Reply With Quote
Old 04-20-2020, 01:02 PM   #11
solidaxel
solidaxel's Avatar
Re: Air intake
Originally Posted by First c10 View Post
I ordered from
.............are you using a Mass Air Flow in the intake tube?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-20-2020, 03:58 PM   #12
First c10
First c10's Avatar
Re: Air intake
Yes it I between the TB and the aluminum Tee.
GO GO!!!
