DIY: Dash vinyl replacement
After seeing a post by another user (Astro-balls) Mitch, I decided to reach out and tackle something I've never even attempted before,...repairing my original cracked dash pad. I was also in luck that Mitch has the Fawn vinyl material, so I went ahead.
Here is the original referenced thread: http://67-72chevytrucks.com/vboard/s...d.php?t=793182 Overall, pretty easy to do. On a scale of 1-10, I'll give it about a 6-7. For the record, I am NOT an upholstery guy, this is the first time I've attempted anything like this. The net, if I can do it, ...you can too ![]() Removing the original vinyl: Take your time and use a HEAT GUN. Get the old vinyl where it's TOO hot to touch (wear gloves). It will soften up like 'stretchy rubber', and literally peel off like a banana peel. You must get it HOT enough, don't underestimate, ...HEAT is your friend here. The goal obviously is to prevent damaging the foam core. It's easy, trust me, but you have to heat it up good. Applying Gorilla Glue: I actually used a business card to spread it over the voids I wanted to fill. It sits overnight to dry and expands. Sand/smooth it out, simple enough. I did do a second application in one area to get it better. Applying the vinyl: Like I said, I'm no upholstery guy, so maybe others have a better way. First I laid the pad atop the vinyl, I then used a sharpie to mark a centerline, then marked an area on the vinyl that corresponded with an area on the pad. I applied glue only to those areas. Starting at the forward edge of the dash pad (noting it is flipped upsidedown as you do this) I worked one section at a time. Eventually wrapping over the 'nose' of the pad (where the 4 philips screws go). The ends were the trickiest part since it tapers down and curves. Even if you have slight crease on the ends, they abut the pillar post area, so you won't see it anyway. The four phillips dash pad screws: I had a tough time getting the recessed area to stay 'stuck' where the screws would go. The heads on the factory four screws are so small I was concerned they would pull through the material. I decided to change those for screws with four black philips screws with washers attached. They worked perfectly. (see last photo for side by side with screws) Something I thought of (after the fact) was to (temporarily) screw four washers into those recesses while the glue is drying. That way, once dry, the material should be flat/flush to the metal dash backing. Anyway, I hope that helps anyone else 'on the fence' about tackling this. It was pretty straight-forward. Thanks to the prior threads and posts that gave me a bump in confidence to tackle this. Of course, Thank You to Mitch (aka Palo Alto Upholstery ![]() ![]() Kevin K My original cracked Fawn color dash pad: ![]() Removal of old vinyl: ![]() Bare foam: ![]() Applying Gorilla glue to areas that needed building up: ![]() Sander used to smooth/form cured Gorilla glue (60 grit belt): (Noting I also did use a sanding block with 180 grit for finer cleanup) ![]() All repaired and ready for new vinyl: ![]() Applied glue in phases, starting on the forward edge of dash first. Contact cement applied to both dash and vinyl, wait 10-15min, then attach... ![]() Working my way around, ...almost there. ![]() Finished product: ![]() Reinstalled... ![]() Factory phillips screws next to replacements I used: ![]() Links to Glue and Adhesive: https://www.amazon.com/00271-Weldwoo...s%2C151&sr=8-2 https://www.amazon.com/Gorilla-Origi...6706182&sr=8-4
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
laying low
![]() Join Date: Mar 2001
Re: DIY: Dash vinyl replacement
Very nice.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Turned out Great....Probably only going to get 50 more years out of it. Good write up...Thanks for posting.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
![]() Join Date: Oct 2009
Never would've thought of doing this - turned out great, thanks for documenting.
Turned out great. What contact cement did you use?
Weldwood DAP, I included Amazon link at end of first post. It came recommended, I would normally have sprayed, but brushing on actually allowed better control of where it was being applied.
![]() Join Date: Apr 2008
Very nice work and write up
71 C10 72 K20 72 K10 Super Kirk |
Looks good, great documentation
![]() Join Date: Feb 2019
I sell the Vinyl for the Dash Recovery kit in The 1967-1972 Chevrolet & GMC Pickups Parts Board.
Also available is the PreSewn dash recovery kit with Saddle Stitched Seam for those that want a custom Dash.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
Did mine the same, way cheaper.
Do it, Do it right, Do it right the first time |
![]() Join Date: Jan 2007
Wow that’s awesome. Nice to know that’s possible!
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
Nice job Kevin. Now, get that truck back together and drive it.
Picture 4, how much was the invoice to get the deer butchered? ![]()
1968 C-20 CST Vermillion http://imageevent.com/happy_dan/dantoys/68c20 2019 Silverado 2012 Camaro ZL1 |
#13 | |
I'm working on getting it back together, ...after I take it more apart ![]()
