Sway Bar / Lower Control Arm Compatibility
My truck came with the DJM Lower Control arm below and no Sway Bar. I would like to install the Sway Bar below but I am not sure they will be compatible.
Can anyone tell me if they will work together. https://www.summitracing.com/parts/d...placementparts https://www.ebay.com/itm/63-72-CHEVY...UAAOSw5dlaLx8o |
Re: Sway Bar / Lower Control Arm Compatibility
The end-link bushing set-up you linked is the same style that those DJM a-arms utilize but that doesn't mean their compatibility is a sure thing. I have 2 sway bars w/end links like that. Each bar is a slightly different width which would cause possible alignment issues if not used on a-arms w/the mount aligned.
If you cannot fabricate, I would verify what swap bar DJM recommends first. I you can fabricate, then @ worst you might need to relocated the a-arm mount placement on the a-arm so the link is plumb/vertical @ ride height.
