Old 04-13-2020, 03:09 PM   #1
conoco
conoco's Avatar
What is this on the back of my rear drum
Is this the emergency brake cable hold down? Can I undo the two bolts and just take it off? I am changing my leaf springs and need to move that cable out of the way so it doesnt get torn off on accident. Any help would be great.
conoco is offline   Reply With Quote
Old 04-13-2020, 03:23 PM   #2
Davidf
Re: What is this on the back of my rear drum
Yes, you can unbolt it, but you also have to disconnect the actual inner cable from the parking brake/show lever (located in the drum) before you can completely pull it away.
Davidf is offline   Reply With Quote
Old 04-13-2020, 03:26 PM   #3
Wrenchbender Ret
Yes. Those 2 bolts hold the cable on. There are nuts on the other side so you will need to pull off the drum. If you want to remove the cable disconnect the cable from the lever that is attached to the shoe.
George
Wrenchbender Ret is offline   Reply With Quote
