04-13-2020, 07:01 PM | #1 |
Biggest tires on rear
I'm looking to buy rubber in bulk. What is the largest rubber to have been confirmed on the back of a suburban? I'm specifically looking to go with 33 12.50 15. As in these stepside pics.
04-13-2020, 08:48 PM | #2 |
Re: Biggest tires on rear
With stock sheet metal, 295mm tread width is the limit, IF you get the right wheel offset.
04-13-2020, 11:59 PM | #3 |
If you want to tub the fenders 4" you can fit 31x16.50R15s in there...
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
04-14-2020, 12:11 PM | #4 |
That is a ton of tire. Probably no tubs for me. Im trying to quit welding on this thing.
I would be happy to run a 10.50 but when you get to 33's they are all mud tires. In a 12.50 there are many tires that are regular tread. I have 275 60 bfg ta's on it now and they were fine but really are a car tire. I want a truck tire and big little look. With 235 75 being little. |
05-10-2020, 09:18 PM | #5 |
33 12.50 is not even in the ball park for the factory wheel well.
My 275 60's measure 28" diameter and 9" of tread with a fair sidewall buldge. Probably 10.5 at widest. I would have to trim the lip to even do a 30 diameter or a 10.5 at the tread. |
06-16-2021, 12:33 AM | #6 |
But Found Her 25yrs Later!
Couldn't find a thread to post this in.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
06-17-2021, 09:47 AM | #7 |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
