Old 04-14-2020, 11:02 AM   #1
Jurassic-1
Jurassic-1's Avatar
Trans Swap
What would it take to put a 1976 3 speed manual trans with column shift in a 1966 C-10 pickup . What would it take to convert it?
Jurassic-1 is offline   Reply With Quote
Old 04-14-2020, 11:21 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Trans Swap
Well does the 66 have a straight six? If so the rear engine/trans cross member needs to come out. Likely need to install a transmission mount cross-member. Possible drive shaft length change. Column shift linkage change. Install a trans fluid cooler. I'm sure I'm missing something.
Old 04-14-2020, 08:45 PM   #3
vince1
Re: Trans Swap
Trans fluid cooler?
vince1 is offline   Reply With Quote
Old 04-14-2020, 09:03 PM   #4
The Rocknrod
Moderator
Re: Trans Swap
Ya you guys probably call it transmission oil eh?
Old 04-14-2020, 09:31 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Trans Swap
Are you guys making recommendations for an auto. I think he wants to put in a 3 speed manual.
66 C20 Service Truck:
Old 04-14-2020, 09:42 PM   #6
Captainfab
60-66 Nut
Re: Trans Swap
A 1976 3 speed manual trans should bolt right up to your bellhousing, unless the front bearing retainer is 5-1/8" in diameter instead of 4-13/16". Not sure about the shift arms or the size of the yoke and u-joint needed.
Old 04-16-2020, 03:25 PM   #7
Pitpig
Re: Trans Swap
Your gonna need the whole 3 speed column, shift rods, springs, etc
Pitpig is offline   Reply With Quote
