Old 04-14-2020, 07:26 PM   #1
Mts67C10K20
Mts67C10K20's Avatar
Stearing column gasket best how to???
So I'm in the home stretch reassembling my 67K20
And before I destroy a new seal is there a better way to install
Besides just stretching it over the shift lever
Thanks all
Mts67C10K20 is offline   Reply With Quote
Old 04-14-2020, 08:31 PM   #2
toolboxchev
Re: Stearing column gasket best how to???
So there is a boot that goes over that spring or is it just a small seal I cannot see in the pic immediately?
I initially am thinking soak it in silicon spray.
toolboxchev is offline   Reply With Quote
Old 04-14-2020, 11:17 PM   #3
FirstOwner69
FirstOwner69's Avatar
If you don't consider slitting it destroying it, you could do as shown in this link to a post in a tilt column FAQ.
http://67-72chevytrucks.com/vboard/s...04&postcount=9
Jim
FirstOwner69 is offline   Reply With Quote
Old 04-15-2020, 10:21 AM   #4
Mts67C10K20
Exactly the info I was looking for
Don't mind doing what's necessary on purpose
Just dont like random oops
Old 04-15-2020, 11:58 AM   #5
clay68c10
clay68c10's Avatar
If it’s new you should be able to stretch it. I’ve stretched a few of the GMC Paul’s gaskets successfully.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 04-15-2020, 05:48 PM   #6
randy500
Those non tilt columns are super easy to work on and dont need any special tools.
Replace it from the top.
Remove the shift lever
Remove the 3 turn signal screws
Remove the tune aignal cover
Remove the ahift bowl
Remove and replace the grommets
Shift bowl probably needs cleaned and lubed anyway.
randy500 is offline   Reply With Quote
Old 04-15-2020, 06:44 PM   #7
Mts67C10K20
Thanks all
Will be installing soon
Old 04-17-2020, 12:09 PM   #8
lousyflyer
Soak it in hot tap water for a few minutes. It will soften the rubber a little.
lousyflyer is offline   Reply With Quote
Old 04-18-2020, 08:52 AM   #9
Mts67C10K20
Thanks all for your input and expertise
I tried the stretch method before doing the hub disassembly
Which works well with a new flexible seal and a shoehorn
