04-15-2020, 12:24 PM | #1 |
Headlights stopped working overnight
72 c10 was parked for years and then just now started to drive it. Last night the headlights worked perfectly but then this morning neither hi or low works. Ideas?
Posted via Mobile Device |
04-15-2020, 12:38 PM | #2 |
Post Whore
Re: Headlights stopped working overnight
I would suggest inspecting the hi/ low floor switch and the wiring to it first. It is fairly easy to access and a common problem area due to moisture. Then the light switch can be checked. First check for 12v between the switch and ground. If you don't have a wiring diagram just do a search above. And this link should help.
http://67-72chevytrucks.com/vboard/s....php?p=6822383 Good luck.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-15-2020, 07:22 PM | #3 |
May be crazy, but it has happen, did both lamps happen to burn out.
04-15-2020, 09:39 PM | #4 |
Just to comment. I've been going through my '68, headlights 'were' working fine, ..then midstream, parking lights OK, but headlights no go. Since I had it all apart, I ordered a new H/L switch, ...and that was it. It just went.
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
04-15-2020, 10:23 PM | #5 |
I remember driving my 70 model as a teenager and when I dimmed the lights once they both went out completely! A flurry of quick left foot clicks got the low beams back on and I drove home without switching again.
Replaced the high/low switch and fixed the problem.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
04-16-2020, 11:10 AM | #6 | |
The parking light, dome light, indicator dimmer functions of the switch do not use the internal circuit breaker.
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights |
04-16-2020, 11:23 AM | #7 | |
If it's indeed "auto resetting", it definitely went since I tried it over the course of a couple days before I put the new one in. Thanks for the info...
04-16-2020, 12:12 PM | #8 |
My understanding of the auto-resetting feature is that if it pops it resets almost instantly. Imaging having to wait many seconds on a dark road for the headlights to come back on after something happened. That's likely why they didn't use fuses to begin with on the headlights (that and the higher current requirements perhaps).
04-18-2020, 03:11 PM | #9 |
Simple testing will tell you where the prob is rather than throwing parts at it.
Get a 12v tester. Cheap and useful Make sure you have a good ground on tester Turn lights on and test for power at the headlight plug. If u have power check grounds. If not just work backwards to dimmer switch in and out Headlight switch in and out etc. https://www.harborfreight.com/6-12-v...iABEgLHm_D_BwE
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
04-28-2020, 10:25 PM | #10 |
Found the problem. Iv heard of some weird stuff happening before but none beat this! Switches all checked out fine. Initially just the high or lows (can’t remember which) both stopped working at virtually the same time. Then about two days later both of the highs stopped working. Would you believe it that both headlights were burned out in both circuits???? I cleaned the connectors and did everything possible and they were both smoked. Changed over the two different headlights that I had on the shelf and everything worked perfectly first time
04-28-2020, 10:39 PM | #11 |
Well I am glad you found the problem.
Those symptoms are usually caused by the dimmer switch.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
04-30-2020, 01:15 PM | #12 | |
Post Whore
