Old 04-15-2020, 03:12 PM   #1
HeavyHauler
Anybody running a 4L80E trans behind their bigblock?
I am looking at getting a 4L80E to put behind my 1975 454 engine. Has anybody else done this. If so then what parts did you use and what modifications are needed to make it fit a 1968 Chevy C10 shortbed.
HeavyHauler is offline   Reply With Quote
Old 04-15-2020, 05:00 PM   #2
2500HD
2500HD's Avatar
Re: Anybody running a 4L80E trans behind their bigblock?
I am behind a ZZ454. You will need a controller. I am using a Compushift 1 now but i am currently changing over to a Compushift sport. Will need a new trans cross member or the factory one could be used but you will have to slide it back some. Will need a TPS . Lastly, you will need to shorten the drive shaft. I have a factory high hump cab so i do not know if there will be any problem with a low hump.
1970 Custom Original 400/400
Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi
PS PB and cold factory air
Early Classic 4.5/6
Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20
Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40
Rear end is original wide 6 lug converted to 5 lug
2500HD is offline   Reply With Quote
Old 04-16-2020, 03:08 PM   #3
HeavyHauler
Do they sell a aftermarket crossmember to fit this trans so I dont have to drill any extra holes or hack up my original frame?
What did you use? My truck is a original factory 396 bigblock with 400 turbo trans.
Old 04-17-2020, 03:12 PM   #4
2500HD
2500HD's Avatar
Factory big block trucks came with the high hump so you are good there. I used a CPP cross member. If i recall i had to drill 2 holes per side in the lower frame rail. If you use the factory cross member you will have to drill hose in the upper and lower frame rails. Really isnt a big deal the holes are 7/16 i think. I assume you have a two piece shaft. What bearing do you have? this is a good time to change to a single shaft. Are you lowered or factory height?
Early Classic 4.5/6
Old 04-17-2020, 05:23 PM   #5
ImNoSpaz
ImNoSpaz's Avatar
I have the low hump and had to fold over the seam at the bottom of cab/tunnel to give the trans a little bit more room. I also tried the aftermarket trans cross member but was not willing to drill holes, so I made my own.
I have the 7.4 vortec with the 4L80e, and used the Ron Francis wiring kit. That's all that was available at the time of purchase. Driveshaft, if I remember right was a 3" aluminum out of a little 80 something c10 and was the perfect length.
ImNoSpaz is offline   Reply With Quote
