Old 12-10-2003, 02:23 AM   #1
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Exclamation BAH!! Stoopid electricity!
Ok, when my truck is idling, in gear, my lights kinda flicker in time with the engine. It doesn't idle all that low, about 800 rpm's. I havn't changed anything and I havn't noticed this before. Do I just have the idle set too low? Unlikely. What could be wrong that causes this?
Cat Fuzz is offline   Reply With Quote
Old 12-10-2003, 02:28 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You have the old stock external regulated system most likely.
Sad enough...it is normal. (good reason to upgrade to a newer internal regulated unit)
Old 12-10-2003, 02:30 AM   #3
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Hmm, can you tell me how thats done? I have an internal regulated alternator already.
Old 12-10-2003, 02:30 AM   #4
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
Your headlights go dim a little bit?! Alternators don't put out too many amps at idle, but still, it may be going bad. Take your alternator out and haul it to the auto parts store and have them check it, it's free. Then you will know for sure.
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 12-10-2003, 02:32 AM   #5
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
It's almost new. Just had it warrentied a couple months ago.
They don't go steady dim, they dim and brighten rapidly, in time with the engine.
Old 12-10-2003, 02:46 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Maybe the flicker suppresor is getting worn out.
Old 12-10-2003, 03:04 AM   #7
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Wink
Eh, is that a real part or
Old 12-10-2003, 03:07 AM   #8
Tx Firefighter
Nah, never mind what I said, your model doesn't use one of those.
I was just being stupid. If you ignore me, I'll probably lose intrest and go away.
Old 12-10-2003, 03:14 AM   #9
Hooter
My other Love
Hooter's Avatar
HAHa flicker dispenser
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 12-10-2003, 03:44 AM   #10
68LSS1
68LSS1's Avatar
Check your grounds. I'd go ahead and clean the battery ground and there's one for the lights. I think it's on the radiator crossmember or inner fender.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 12-20-2003, 01:46 AM   #11
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Question
UPDATE:
It seems to go away as the truck warms up. Grounds seem to be fine.
Old 12-20-2003, 01:50 AM   #12
jorgensensc
jorgensensc's Avatar
Tx Firefighter
Is that like turn signal fluid??
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 12-20-2003, 02:47 AM   #13
Rooster's 67
Rooster's 67's Avatar
nah,
It is more like a loose nut somewhere behind the steering wheel.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 12-20-2003, 02:52 AM   #14
Rooster's 67
Sorry Cat Fuzz,
Couldnt help myself
Old 12-20-2003, 03:20 AM   #15
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Originally posted by Rooster's 67
Sorry Cat Fuzz,
Couldnt help myself
LOL!! I get it! I should check the steering wheel nuts!
Old 12-20-2003, 03:58 AM   #16
Rooster's 67
BEHIND the STEERING WHEEL........
What is behind the steering wheel????
Old 12-20-2003, 03:59 AM   #17
Rooster's 67
it is an old mechanics term,,,,,,,
the person behind the wheel is a loose nut.
no offense meant at all
I just cant help my self some times.
Old 12-20-2003, 07:48 AM   #18
oldyeller
Captain CAAAVVVMMMAAANNN!
oldyeller's Avatar
hey Rooster, you talkin to yourself again ??
72 LWB Fleetside C10 Custom 350/350
97 GMC Yukon 4X4 SLT
Anna, Texas
check out the project old yeller
oldyeller is offline   Reply With Quote
Old 12-20-2003, 10:57 AM   #19
Rooster's 67
sump-tin like that
Old 12-20-2003, 01:40 PM   #20
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
WOW we didn't get away from the problem of flickering lights by chance did we???? My guess would be to goose the engine off of the idle and see if it takes care of that. I'd check the ground at the radiator support but i'd also check the grounds in the turn signal lamps up front. The bulb socket in mine was loose awhile back and was causing mass hysteria to my truck!!! Everything was blinking when it wasn't supposed to be!!! If you're grounds are good well then I'd just hook the multimeter to it and check your volts. If the volts thats go to your headlights fluctuate well then it ain't a ground on the lighting side. More than like an alternator or something of the sorts
WRMZ71 is offline   Reply With Quote
Old 12-20-2003, 02:35 PM   #21
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
No, we havn't found a solution yet. I havn't even looked yet cause its cold and my wife and son have both been sick. Maybe I'll get some time today.
I'm pretty sure that the voltage is fluctuating through-out the electrical system (dash lights, dome light, tail lights all flicker as well). When it is flickering the most is when its cold and my amp gauge twitters a bit to the charge side. Revving the engine only increases the frequency and eventually to a point where its not noticable. I gotta get it up to around 1300 rpm's for that though. But if I had an oscilloscope, I'm sure I could still measure a voltage fluctuation even at higher rpm's.
I just have to fire up my little propane heater in the garage and take a looksy.
Old 12-20-2003, 03:38 PM   #22
Rooster's 67
you could have a bad diode trio in the alt, yank it off and have it checked
Old 12-20-2003, 04:15 PM   #23
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Thumbs up
Ah, yes. I hadn't thought of that. I have an ohm meter, I'll just take it apart and check it myself.
Old 12-20-2003, 04:40 PM   #24
Rooster's 67
booyah......someone that knows a little bout that durn electricity.
Old 12-20-2003, 05:06 PM   #25
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
lol, I have an AA degree in electronics. Forgot some of it, but most of it is like riding a bike.
