04-17-2020, 04:20 PM | #1 |
WTB Quadrajet 704128 - parts carb
Wanting either decent main body or parts carb due to cracked damaged body on mine. Important part is that main body is rebuild-able. This is on a 72 with 350 Auto. Let me know what you have.
04-18-2020, 05:17 AM | #2 |
Re: WTB Quadrajet 704128 - parts carb
The casting number on early carburetors should be 7 digits. What is the complete casting number on your Qjet?
04-18-2020, 07:50 AM | #3 |
Should be 7042208. or 7042210
04-18-2020, 08:33 AM | #4 |
Ouch...my mistake.
my carb is 7041208. This carb is not the original for the truck, but this is the carb I am trying to repair. Would consider a different casting, correct for a 72 350 auto c-10. I may need to do a bit more research, but not overly concerned with a matching numbers carb since this is not the original carb, nor original engine. thanks for catching the missing digit. |
04-18-2020, 09:06 AM | #5 | |
thanks. |
04-18-2020, 12:35 PM | #6 |
I might have one if these guys can’t help you.
Tony |
04-18-2020, 05:39 PM | #7 |
i have them for automatic with new throttle shaft bushings installed disassembled and cleaned have parts also 7042208
04-18-2020, 05:48 PM | #8 |
Would you happen to have a decent main body (only)? Carb I have is nice, except for a crack in the main body, so ideally I would like to just swap in a good body.
04-19-2020, 06:22 PM | #9 |
Thanks to all who offered up carbs. One of the fellow board members offered up a carb body which should work to replace the cracked one on mine.
thanks |
04-21-2020, 02:45 PM | #10 | |
I sent you a PM on distributors Jess
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
