Old 04-17-2020, 06:16 PM   #1
Lugnutz65
Lugnutz65's Avatar
PS pump differences.
I’m putting together parts for my LM7 Vortec 5.3 build. I bought a new PS from RockAuto but it doesn’t match my old one (which is a remanufactured one I got with parts I bought from a salvage yard 5.3).
I need guidance here.
The large piece that bends at a right angle is part of the reservoir and can’t be removed. The stem sticking straight back is a sensor.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 04-17-2020, 10:14 PM   #2
ls1nova71
ls1nova71's Avatar
Re: PS pump differences.
That fitting can be removed. It may be tight, but it will unscrew out of the reservoir.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-18-2020, 08:41 AM   #3
Lugnutz65
Lugnutz65's Avatar
Thank you very much. Mission accomplished. My son had convinced me it was part of the case. Next I’ll see if I can hook it up to the new pump.
Old 04-18-2020, 10:55 AM   #4
Lugnutz65
Lugnutz65's Avatar
Success! Swapped over after I removed the nut on the new pump. I sure hope this all works once installed.
Old 04-18-2020, 11:16 AM   #5
ls1nova71
ls1nova71's Avatar
I thought you were going the other way with it for some reason. But curious, why you want to use that piece? Usually that piece will cause interference problems, but if you don't have any problem with clearance, shouldn't hurt to use it.
Old 04-18-2020, 01:21 PM   #6
Lugnutz65
Lugnutz65's Avatar
The pump has a sensor on that piece. Don’t I need to give the computer a sensor reading? I can just run a hard line out of the back of the pump and delete the sensor. What do most people do? I will use the Holley Terminator X wiring harness and ECM.
Old 04-19-2020, 12:51 AM   #7
pcmcobra
pcmcobra's Avatar
Don't need sensor on power steering pump...
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
