04-17-2020, 06:35 PM | #1 |
4L60E wiring question 72 K10 LQ4
After much thought and good comments from members I decided not to install the 700R4 and switch my transmission to a 4L60E..so I traded the transmission I had for a rebuilt 4L60E and have installed in my 72 K10 with a np205 transfer case.
Both are 27 spline. I repinned my own harness a few years back and removed the transmission control wires..so I have made a new harness for the trans and connected it as this per these drawings.. The question I have is where does the pink connector E (round plug) get it's power from? Pin 75 blue on ecm... Or do I have to add a splice to it to give it key-on power? I don't think I need the neutral switch(C2) as the truck already has a working one in the column, and is wired as such. (truck was running a TH350 for last few years) Thanks
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
04-17-2020, 10:12 PM | #2 |
Re: 4L60E wiring question 72 K10 LQ4
The power to the transmission plug comes from the main ignition relay, the same one that powers the rest of the LS harness. it should also be fused, generally 10a.
You don't necessarily need the neutral safety switch on the transmission if you are going to use the column mounted one.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
04-18-2020, 01:26 AM | #3 |
Thanks that's what I figured from the drawing. Just need to reflash my ECM as it's flashed for a 4L80E
