04-18-2020, 01:51 PM | #1 |
250 V-6 Club
250 oil guage
I have a 70 c10 with a 250. I already rewired and hand the gauge cluster to go from dummy light to gauges. My question is (since I don’t like the idea of oil in the cab) is there and gauges out there that look like the original but that are digital? Or has anyone been able to convert their gauge? Tia
1970 Chevy C/10 6 Cyl. 43k original miles all factory .http://67-72chevytrucks.com/vboard/s...d.php?t=197523 Never ask a stupid question unless you want a stupid answer . |
04-18-2020, 03:56 PM | #2 |
Re: 250 oil guage
dakota digital
I BELIEVE IN JOHN 3:16 |
04-18-2020, 04:09 PM | #3 |
Re: 250 oil guage
The Dakota Digital solution is excellent, but pricy. VDO, Stewart-Warner all make line of electrical gauges that use a pressure sensor with a single wire connection on the engine.
04-18-2020, 05:08 PM | #4 |
Post Whore
Re: 250 oil guage
Drop a PM to Tbone1964 he may be able to convert your existing oil gauge to an electrical gauge. He is the resident expert on gauge restoration and upgrades.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-18-2020, 06:15 PM | #5 |
250 V-6 Club
Re: 250 oil guage
Great thanks. I will check them all out
04-18-2020, 09:11 PM | #6 |
Re: 250 oil guage
Why dont you like the oil going to the gage? I have replaced every electric oil psi gauge to mechanical. I dont trust electrical
04-18-2020, 09:25 PM | #7 |
Who Changed This?
Re: 250 oil guage
My live oil pressure gauge has been in the truck for 50 years and hasn't leaked yet. One rebuild in the mix about 100k miles ago.
04-19-2020, 12:10 AM | #8 |
250 V-6 Club
Re: 250 oil guage
Was a thought. I have seen a line bust in my dads 67 about 3 in from the gauge and shot oil all over the cab. I did check and it would cost a lot to go digital. question = how many psi at the original gauges? and it there a way i can test it before i connect it oil? What would you recommend plastic or brass line? and is there a kit out there as it has dummy lights before that would make it easier. thanks
04-19-2020, 06:30 AM | #9 | |
Re: 250 oil guage
I know how you feel, I once got dirty black oil over some new tan suede pull-on boots when the connector on the back of the Oil Pressure gauge came loose. I'd been working on the dash lights and had loosened the OP gauge to get better access. My own fault. The truck, a '71 GMC Jimmy with deluxe gauges, was new to me. The old truck had the idiot lights. How much PSI? My Gauge, a Stewart-Warner, reads about 40 PSI running normal, warmed up. It can get up to 60 PSI. I have a 292, but it should be similar. There are ways of keeping the Idiot Light functions and using a mechanical gauge. It takes a special fitting that includes both probes, I think. The oil stains came out with some talc powder and a brass suede brush. I think it gave them ''character.'' But I've never had that same problem again, since I know about it.
04-19-2020, 10:53 AM | #10 | |
Who Changed This?
Re: 250 oil guage
04-19-2020, 10:57 AM | #11 | |
The Older Generation
Re: 250 oil guage
I have copper oil pressure line kits with original fittings. http://67-72chevytrucks.com/vboard/s...d.php?t=788124 LockDoc
04-19-2020, 11:58 AM | #12 |
Just here to tinker
Re: 250 oil guage
Definitely go with copper. I've had plastic fail on my 78 and destroyed the carpet with oil. Never heard of the copper ones failing....
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
04-19-2020, 12:58 PM | #13 |
Post Whore
Re: 250 oil guage
Another route to go would be to use a high pressure fuel guage isolator. That will keep the oil in front of the firewall. It may seem spendy but probably not when compared to all the other options, short of just replacing the old line with a new one.
https://www.jegs.com/p/Auto-Meter/Au...51840/10002/-1
04-19-2020, 07:32 PM | #14 | |
Re: 250 oil guage
I've had the metal Oil Pressure feed line to my gauge in my '68 C /10 [292 L6] since about 1978. Metal fatigue? Maybe if I was going about 400 - 450 knots and doing 5 - 7 G manuevers for hundreds of hours, I might need to worry about it. But I rarely catch air anymore.
04-23-2020, 01:31 PM | #15 |
250 V-6 Club
Re: 250 oil guage
Well went ahead and ordered a new gauge as well at the copper line kit (wish I had seen docs first). One thing that comes to mind is, is there a fitting that goes into the block that the line would go to? Or does the line go straight to the block? Got it from lmc. If I do need a fitting for the block does anyone know the size? Thanks as always
