Junior Member
![]() Join Date: May 2016
RV column
can you move the nss on a rv tilt column without taking it apart?
![]() Join Date: Jul 2016
Re: RV column
Yes its a little tricky since the shift tube only has 1/4” gap between it and the outer tube.
If you re-use the rv switch you can drill a hole in the shift tube to accept the switch instead of the factory rectangular hole. Rv switch wiring connector is different shape but you can make it work, dont splice just release the factory wiring terminals and insert them in the rv style connectors. |
![]() Join Date: May 2010
Re: RV column
This thread has good info. Of course, with the RV column it is not necessary to collapse the intermediate shaft.
http://67-72chevytrucks.com/vboard/s...d.php?t=147927
Jim |
Tags |
rv column |
