Old 12-10-2003, 09:57 AM   #1
butter
butter's Avatar
one more time tire size
Who is running 17x9.5 or 17x11 on the rear and what is the biggest tire you can run with out scrubbing. Pictures Please
71 cheyenne 402 th400 swb
71 camper special (PARTS TRUCK)
70 Stepside swb 350
butter is offline   Reply With Quote
Old 12-10-2003, 11:19 AM   #2
RED71CHEVY
RED71CHEVY's Avatar
I AM RUNNING 17x9.5 EAGLE ALLOY 211 WITH 4.5 BS, TIRE SIZE IS 285-60-17, THEY ARE ABOUT 30.5" TALL AND HAVE A 11.5" SEC WIDTH, ALSO REAR HAS A 4" DROP WITH COIL SPRINGS.
I SHOULD HAVE GONE WITH A 5" BS. I GET SOME SLIGHT RUBBING WHEN I TURN IN TO A DRIVEWAY THAT GOES UP HILL, THE BODY FLEX LETS THE BED MOVE, I AM GOING TO TRY AN ADJ PAN HARD BAR TO RECENTER THE REAR, ALSO I HAVE A NEW SWAY BAR SETUP THAT I AM GOING TO TRY ON THE REAR.
TIM
'71 CUSTOM C-10 torch red ,350 roller GM crate,3.73 GEARS, REAR 4"DROP SPRING, FRONT 2.5" DROP SPINDLE-1.5"lower spring, FRONT=17x8(4.5bs) W/265-60-17, BACK=17x9.5 (5bs)W/285-60-17, Vintage Air Sure Fit AC------NEVER ENDING PROJECT!!
RED71CHEVY is offline   Reply With Quote
Old 12-10-2003, 01:30 PM   #3
butter
butter's Avatar
Thanks red71chevy that is what Iam looking for. Do you still have stock wheel tubs?
70 Stepside swb 350
Old 12-10-2003, 07:20 PM   #4
butter
butter's Avatar
ttt
70 Stepside swb 350
Old 12-11-2003, 01:33 PM   #5
RED71CHEVY
RED71CHEVY's Avatar
the tubs are stock, fleet side bed. good luck.
TIM
Old 12-11-2003, 02:06 PM   #6
Ackattack
Ackattack's Avatar
I have looked into getting 17x11 for my truck, but here is why I have decided not to. I think a truck needs more sidewall than a car, so I want to run 275/50/17s up front on a 17x9 or 9.5 rim. On the back alls I could find was 315/35/17...much shorter than the fronts would be. So I will go with the 17x9 rims all the way around.
Ackattack is offline   Reply With Quote
Old 12-11-2003, 05:40 PM   #7
butter
butter's Avatar
Thanks red71chevy for the info.
70 Stepside swb 350
Old 12-11-2003, 06:47 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
I have a set of 17x8 and 17x9.5 Eagle 212's, that I ran on my old '82 2wd Blazer. I ran Nitto 255/50's and 275/50's with no problems. These are pretty affordable tires. I hope to run them on my '71 swb. 5 inch backspace on the front and 4.5 inch backspace on the back.
Old 12-13-2003, 09:56 PM   #9
RED71CHEVY
RED71CHEVY's Avatar
i have 265-60-17 at the front and 285-60-17 at the back.
i had been running eagle 212's 17x8 all around with 275-55-17...
both tire combinations give more that 5"+ of side wall, they look good and you still can haul the trash off without worring about pot holes, road joints, and the uneven pavement!!!!
TIM
