Old 04-19-2020, 03:32 PM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
My speedometer is now accurate
I’ve had problems with my speedometer head since post-build mile number one. The initial one had a busted odometer. This was swapped for a nice one supplied by member Tbone1964 (Tom). Given the rear end gear change and tire diameter increase the speedometer was off. Today I was able to correct the error with the addition of a gear ratio adapter from Deluxe Speedometer and Cable Service of Denver. They created the adapter in the ratio needed for my error based on comparison readings with a GPS receiver. I’m super pleased. Good service and price. USA made Eaton parts.
https://speedometercablesusa.com/
Old 04-19-2020, 07:28 PM   #2
WorkinLonghorn
WorkinLonghorn's Avatar
Re: My speedometer is now accurate
Thanks DeadheadNM, I didn't know they still made these adapters. My old +10% original needs replacement.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 04-19-2020, 08:17 PM   #3
truckster
truckster's Avatar
This is what I'm looking for on as much stuff as I can find:
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 04-19-2020, 08:43 PM   #4
SeventyOne
Super helpful piece of the puzzle. thanks!
SeventyOne is offline   Reply With Quote
Old 04-19-2020, 10:40 PM   #5
wesmigletz
wesmigletz's Avatar
Thanks for sharing. I have a few vehicles I would like to correct.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
Old 04-20-2020, 08:54 AM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Absolutely!!
I needed about a 13% bump in speed at the speedo. This box has a ratio of about 1.13. Cost $108 with shipping and I got a pen from the business too. Most of you probably are aware but these K5s had a ratio adapter as standard from GM. I had a stock 1.3 or so adapter lying around and that turned out to be exactly what I needed for my k20.
Old 04-20-2020, 11:56 AM   #7
SeventyOne
Originally Posted by DeadheadNM View Post
Absolutely!!
On that note do you know if all the stock K5 adapters were the same ratio?
Old 04-20-2020, 06:11 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
These were not. I believe the gear ratio in the rear axle was a big discriminator but I'll need to research that in the parts manual. I suspect there are two ratios one near 0.97 the other near 1.3 but these are a guess. I'll try to firm up the knowledge and repost. There are gear drives in the transmission that come into play as well and I suspect it's because of these that there are only two ratio adapters.
EDIT: this chart from the parts manual lists two adapters for a 3.73 rear end and several for 3.07. The chart is for four speed manual transmission equipped trucks. There are other charts for auto and three speed manual.
Old 05-26-2020, 08:07 PM   #9
SeventyOne
Interesting. I just emailed speedocableUSA to get a correct adaptor as I think I'm running about 22% too fast. But I have 4.56 gears and 37'" tires so
Old 05-26-2020, 09:02 PM   #10
jjzepplin
jjzepplin's Avatar
Man I got like six of those things. I guess I best get them out and take a look see.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 05-26-2020, 09:03 PM   #11
SeventyOne
Ha yeah i got one. It's just wrong
Old 05-26-2020, 09:17 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Let us know what shakes out.
Old 05-27-2020, 09:28 AM   #13
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
This is great to hear. I'm needing one too.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 06-22-2020, 08:07 PM   #14
SeventyOne
Snapped a pics of my existing adapter:
"666F 01"
"1.2020"
Funny thing is my speedo seems to be a be about 20% too fast
Old 06-23-2020, 08:04 AM   #15
JMac11
JMac11's Avatar
Need to check mine, it's 10mph slow
JMac11 is offline   Reply With Quote
Old 06-23-2020, 12:49 PM   #16
MJN
MJN's Avatar
Great to see USA made. I had the same issue with my '74 K/20 and had a gearbox made up by the guys at Transmission Center, www.transmissioncenter.net If I recall mine was about 17% off when I took my speed measurements compared to GPS
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 06-23-2020, 07:51 PM   #17
2006gmcdmax
Thanks for sharing the information! This was much needed!
2006gmcdmax is offline   Reply With Quote
Old 06-24-2020, 07:40 AM   #18
jjzepplin
jjzepplin's Avatar
"666F 01"
"1.2020"
Attachment 2026783
If you take the adapter out of the equation, what happens?
Old 06-24-2020, 12:04 PM   #19
SeventyOne
I haven't gotten that far
Not sure if the speedo cable will thread onto the Tcase, or If I need a 0% adapter.
Old 06-24-2020, 12:09 PM   #20
jjzepplin
jjzepplin's Avatar
It should fit right in if it is original. The adapter just fits in between the cable and the t case to change the ratio.
Old 06-24-2020, 02:18 PM   #21
SeventyOne
I'll give it a shot!
Old 02-05-2021, 04:57 PM   #22
69Tom
69Tom's Avatar
Good info. Thanks!
69Tom is offline   Reply With Quote
Old 02-07-2021, 03:37 AM   #23
K5Fan
I have the exact adapter that SeventyOne has, and my speedo is 10 miles an hour low, but gets worse the faster I go! I also have the 4 speed with the granny gear.
DeadHead, when you got your adapter did you have to tell them what size tires you were running? I looked at the website, and the picture of the chart you posted, but I couldn't see where it related to the tire size. Maybe I'll take a fresh look at it tomorrow. Thanks Pete!
Chris.
K5Fan is offline   Reply With Quote
Old 02-07-2021, 03:38 AM   #24
K5Fan
Duh, I see the tire size now. Thanks again.
Old 02-07-2021, 10:49 AM   #25
Ironhorse
Ironhorse's Avatar
Several years ago I had the same issue with my speedometer being off. 71 4x4 after a swap from manual to auto transmission. I run 31x10.50x15s on 8'' rally wheels. I noted my speedometer reading against a GPS phone app and figured the difference. Contacted www.transmissioncenter.net and gave them the information. They built me an adapter that after an easy 15 minute installation was dead on with the speedometer and the phone app GPS speed. Just attached to the side of the transmission where the speedometer cable attaches.
Think my cost then was around $65 plus shipping but I'm sure costs are higher now. Very easy to do without going in to the transmission and changing the plastic gears.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
